Hello, I just purchased the 10m ZED 2i USB 3.0 Type-C Dual Screw Locking Cable and was wondering if there is any documentation on how to use it. It worked fine on my ZED 2i without powering what I assume are usb repeaters.
Hi @JoeyASleiman
The repeater must be powered with an external 5V supplier only if the USB3 controller that you are using is not providing enough power to correctly drive the camera.
If your ZED 2i works correctly you can use it without external power.
Well noted, thank you!
