Tomas
1
Dear Stereolabls team,
I am encountering strange flashes (glitches) in RGB stream of ZED 2i. Please see the video example captured using ZED Explorer:
https://www.swisstransfer.com/d/554c1ecf-c4e0-4a5e-9cce-2e805018db77
How can I fix this?
Thank you and KR,
Tomas
Myzhar
2
Hi @Tomas
The glitches in the SVO that you shared are typically caused by connection issues.
Please check that:
- The USB3 port is not broken (try other ports)
- The cable is not damaged
- The screws of the ZED 2i connector are strongly strengthened
- You are not using USB3 hubs or long cable extenders
- The USB3 cable is not close to electrical noise sources
