Zed 2i is not Detected in zed diagnostic
Zed 2i is works in the Zed explorer but not works in diagnostic, depth viewer, and other application
also works in the windows camera and visible in the ports
why this happen?
can i share the diagnostic reports
Hi @v_agg
We need more details about your device’s status and system configuration to gain a clearer insight into the cause of your issue.
Could you connect the camera to the USB3 port, launch the ZED Diagnostic tool, and send the report file it produces?
yes here it is,
Hi @v_agg
The camera is detected as a USB2 device instead of USB3.
Possible reasons:
  • You connected the camera to a USB2 port
  • You connected the camera to a USB2 hub
  • You are not using the original cable
  • You are using not supported cable extender
  • The screws of the original Stereolabs cable and not strengthened
  • The cable is broken
