I run ZED_Diagnosis, and got this error:
Cannot find TENSORT
sh: 1: glxinfo: not found
glxinfo not found
"Errors occurred<br/>A detailed report can be saved to be shared with support if needed."
"<b>Loading ZED binaries :</b> libnvinfer.so.10: cannot open shared object file: No such file or directory"
"Multiple version of CUDA has been detected. It is recommended to uninstall other versions than 13."
"<b>Object detection</b> module corrupted. Please reinstall the ZED SDK and enable the Object Detection option."
QPixmap::scaled: Pixmap is a null pixmap
Cannot find TENSORT
glxinfo not found
How can I fix it?
When I reinstall the ZED SDK, I got this:
To continue you have to accept the EULA. Accept [Y/n] ?y
Installing...
ZED SDK will be installed in: /usr/local/zed
[sudo] password for yhu:
Checking CUDA version...
ERROR : Found CUDA 12.8 but the ZED SDK requires 13.0
Do you want to install CUDA 13.0 automatically [Y/n] ?n
The ZED will NOT work with this CUDA version (12.8), Continue [Y/n] ?n
Exiting
Actually, I have cuda 12.8 and cuda 13.0. How this error might come out?
