We are using Zed 2i Stereo Camera (Polarizer:With FOV:2.1mm). But we met below two issues.
- Camera Freezing During Operation
■ Environment
- OS: Windows 10
- ZED version 5.0.5+gpu5070 / ZED version 5.0.2+gpu4070 / ZED version 4.2.1+gpu4070
■ Symptoms
- The camera suddenly stops updating the video feed during operation.
- The issue is not resolved until the application is restarted or the camera is reconnected.
■ Frequency of Occurrence
- In some cases, it occurs within approximately 30 minutes.
- In other cases, it occurs after more than 7 days of normal operation.
- A clear pattern regarding specific times or conditions has not yet been identified.
Attachment: Image file showing the frozen state.
- Abnormal Camera Video Contrast/Brightness
■ Environment
- OS: Windows 10
■ Symptoms
- Occurs at startup.
- Despite the same environment, the video contrast and overall brightness change abnormally.
- Excessively dark or contrast-broken video is output.
- Refer to the normal video and the video when the abnormality occurs.
Video file showing the abnormal phenomenon
Normal video image (or video) file Version 5.0.5+gpu5070
■ Symptoms
Occurs at startup
Despite the same environment, the contrast and overall brightness of the video change abnormally.
The output video is excessively dark or has broken contrast.
Refer to the normal video and the video where the problem occurred.
Video file exhibiting the abnormal behavior
- Normal video image file
Thanks,
