Hi all,
We calibrated a ZED 2 (stereo + IMU) with Open MVIS, a free, open-source camera-IMU calibration toolbox, and compared it with the Kalibr calibration published with the same recording. Sharing in case it is useful to others calibrating ZED cameras.
Data. The raw calibration recording of the WHUVID dataset (Wuhan University; Chen et al., Remote Sensing 14(9) 2033, 2022, CC BY 4.0): one ZED 2, 1280×720 mono at 19.7 Hz, IMU at about 381 Hz, AprilGrid 6×6, 74 s. This is one unit recorded by a third party, and the comparison is against their Kalibr result, not against the Stereolabs factory calibration (the recording does not include it).
Setup. Pinhole-radtan (Kalibr’s model), stereo camera-IMU solve with intrinsics free and the rolling-shutter readout estimated. Kalibr assumes a global shutter.
| Open MVIS | Kalibr (WHUVID) | Difference | |
| Rolling-shutter readout | 14.1 / 14.0 ms (cam0 / cam1) | not modelled | |
| Median reprojection error | 0.29 / 0.27 px | 0.43 / 0.53 px | |
| Time offset, mid-image row | +4.54 / +4.55 ms | +4.64 / +4.27 ms | 0.1 / 0.3 ms |
| fx, fy cam0 | 532.5, 534.4 | 526.8, 529.3 | +5.7, +5.1 px |
| fx, fy cam1 | 532.7, 536.0 | 524.9, 529.9 | +7.8, +6.1 px |
| cx, cy cam0 | 636.9, 361.4 | 638.4, 363.0 | −1.5, −1.6 px |
| cx, cy cam1 | 654.6, 340.7 | 656.2, 343.6 | −1.6, −2.9 px |
| Stereo baseline | 120.14 mm | 120.10 mm | 0.04 mm |
| Stereo rotation | 2.8 mrad | ||
| Camera position in IMU frame, cam0 | (−0.2, −24.1, −21.3) mm | (1.8, −22.6, −22.5) mm | 2.8 mm |
| Camera position in IMU frame, cam1 | (−0.4, 96.0, −23.3) mm | (3.0, 97.5, −23.1) mm | 3.7 mm |
| Camera-IMU rotation | 7.2 / 7.7 mrad* | ||
| IMU | Kalibr calibrated model: ideal IMU, only biases estimated |
| Gyroscope scale x, y, z | 1.0052, 0.9875, 0.9857 | 1, 1, 1 (fixed) | +0.5, −1.2, −1.4 % |
| Gyroscope non-orthogonality (shear) | −0.0023, 0.0050, −0.0029 | 0 (fixed) | |
| Gyroscope-to-accelerometer misalignment | 17.7 mrad (1.0°); rotation vector −13.2, 8.0, 8.6 mrad | 0 (fixed) | 17.7 mrad |
| Gyroscope-to-accelerometer time offset | +3.1 ± 0.4 ms (accel later than gyro) ** | 0 (fixed) | 3.1 ms |
| Accelerometer scale x, y, z | 0.9981, 0.9988, 1.0011 | 1, 1, 1 (fixed) | −0.2, −0.1, +0.1 % |
| Accelerometer non-orthogonality (xy, xz, yz) | −0.0063, 0.0044, 0.0125 | 0 (fixed) | |
| Gyroscope bias x, y, z | −0.40, 2.12, −0.84 mrad/s | estimated, not reported | |
| Accelerometer bias x, y, z | 0.016, −0.023, −0.042 m/s² | estimated, not reported | |
| IMU noise densities | from the WHUVID imu.yaml |
same |
* 19–21 mrad in the accelerometer frame. MVIS also estimates a gyroscope-accelerometer misalignment of about 18 mrad, which Kalibr’s IMU model does not include; in the gyroscope frame the difference is 7.2 / 7.7 mrad.
** A solver-free check on the raw IMU stream (correlating the measured accelerometer derivative with the gyro-predicted one) gives +2 to +5 ms across frequency bands, about +4 ms in most, in line with the solver.
On this unit the IMU terms are not negligible: the gyroscope scales are off by up to 1.4 %, and the 1° gyro-accelerometer misalignment is why the camera-IMU rotations differ by 19–21 mrad in the accelerometer frame but only 7–8 mrad in the gyroscope frame.
What we took from it:
- The rolling shutter matters on the ZED 2. Estimating the readout (about 14 ms per frame) lowers the median reprojection error from 0.36 px (global-shutter model, same solver) to 0.28 px.
- The focal length moves with the shutter model. With a global-shutter model our camera-only fx matches Kalibr (526.6 vs 526.8 px); modelling the readout moves it to about 532 px. If you use ZED images with a global-shutter model, the Kalibr-style value is the consistent one.
- Time offset agrees with Kalibr within 0.1 ms on cam0 once the readout is referred to the middle row (MVIS reports it at the first row: −2.49 ms).
- Recording tip. Two IMU messages in this bag repeat the previous sample exactly. Tools that need strictly increasing IMU stamps reject the bag until they are dropped; a small script for this is with the results.
Device wiki page (results, configs, reports): Stereolabs ZED 2 camera–IMU calibration | OpenMVIS
Recording copy, configs and results on Hugging Face: calibench-vi/community · Datasets at Hugging Face (folder zed2). Everything is free to reuse under CC BY 4.0.
Next we would like to do the same with a ZED X or ZED 2i SVO2 recording and compare against the factory calibration file and camera_imu_transform. If anyone has a raw calibration recording they are happy to share, we will calibrate it for free and post the comparison here.
Open MVIS · contact@openmvis.com
