jft_ch
September 18, 2025, 10:01am
1
Hello!
I am having some trouble in getting the ZED Box WiFi to work. It worked on the first boot, but now the WiFi menus display “No Wi-Fi Adapter Found”. I have tried solutions from other posts (related to modprobe), but they all seem to fail. Is there an easy and fast way to get WiFi running without having to completely reinstall the SDK? I have something urgent to do, so taking that step is definitely not an option
Thank you in advance!
Myzhar
September 18, 2025, 10:04am
2
jft_ch
September 18, 2025, 10:47am
3
Hi!
Thank you for the tip, but unfortunately it did not work. Could you recommend something else?
jft_ch
September 18, 2025, 11:06am
4
For reference, if I run ‘ipconfig’, the wifi interface is not even listed.
Myzhar
September 18, 2025, 12:26pm
5
What’s the output of lspci?
jft_ch
September 18, 2025, 12:43pm
6
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0004:01:00.0 Non-Volatile memory controller: Device 1d79:2267 (rev 03)
0007:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1)
0007:01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
0008:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Myzhar
September 18, 2025, 4:08pm
7
The WiFi card is detected, so it’s working.
Please try again the procedure to recover the driver.
If the procedure fails, I recommend you flash the device to restore the file system.
What’s the output of the command cat /etc/nv_tegra_release?
jft_ch
September 22, 2025, 6:26am
8
# R36 (release), REVISION: 3.0, GCID: 36923193, BOARD: generic, EABI: aarch64, DATE: Fri Jul 19 23:24:25 UTC 2024
# KERNEL_VARIANT: oot
Myzhar
September 23, 2025, 10:24am
9
Please flash the device to restore it:
