Whether it can be supported 25m or not
We are using ZED X and hope to check whether 25m distance are possible or not via GMSL 2 cable. Or if not, Could you recommend any solution to overcome this issue for us?
Ryan.
Hi @RyanLee,
Our internal tests have shown that when going above 15m (i.e. 16m-20m), most of the signal is lost, and this increases the risk of the camera being disconnected, therefore we recommend going up to 15m using GMSL2 cameras.
The other solution that we suggest is to use our Streaming Module to stream ZED data through Ethernet, which can obtain much longer cable lengths.
Hi @mattrouss
Thank you for your answer. it helps me a lot.
Ryan.
