I get the last float data at pointcloud API,
point_cloud = sl.Mat()
zed.retrieve_measure(point_cloud, sl.MEASURE.XYZRGBA)
the data demo is “-300921531830117489423516037643325407232.00000”,I don’t how concatenated R,G,B,A,and I don’t know how get the real data of R,G,B,A.
Can someone help me?thanks!
Hi @CharlesDCXX,
The last coordinate of your point_cloud mat indeed contains your color information. It is represented as an array of 4 unsigned char stored into a 32-bit float. In order to extract the 4 unsigned char values, you can use the following code snippet (using the Python struct package - doc here):
import struct
err, point_cloud_value = point_cloud.get_data(x,y) # Get your point cloud value at pixel (x,y)
packed = struck.pack('f', point_cloud_value[3])
char_array = struct.unpack('BBBB', packed)
print("(R,G,B,A) = {}".format(char_array))
It indeed does not appear in the documentation and it will be added for more clarity.
Hope it helps !
thanks!!
This is exactly what i need!!
