bmegli
1
Is there any known waterproof AGX Orin system (let’s say at least IP65) with known/supported GMSL support for ZED-X?
From this post:
I understand that only selected carrier boards/GMSL capture cards are supported and are listed at the bottom of:
Would for example system like this work with ZED-X
What specifically needs to be done to make baseboard/capture card compatible with ZED-X?
In general what is holding ZED-X support with third party GMSL capture cards?
Kind regards
Myzhar
2
Hi @bmegli
I recommend you explore the solutions provided by our partners.
bmegli
3
Those seem to be both waterproof and supported according to Stereolabs list:
Myzhar
4
Yes, we also have a bundle in our store using it:
bmegli
5
It would still help if some generic information what is required from hardware/baseboard/capture card/driver to support the cameras.
For example Connect Tech is on partners list.
Has own lists of supported hardware.
https://connecttech.com/supported-cameras/
ZED-X is listed as supported by Anvil but not by Anvil RX.
Typically no immediate information what baseboard/capture cards are in manufacturer’s solution is directly available.
Myzhar
6
Hi @bmegli
I recommend you reach out to Connect Tech for additional specific information concerning their products.
