I am not using Anaconda for this project but I have an activated venv within my VS Code project. My pip installs look like this:
(venv) PS C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024> pip list
Package Version
certifi 2024.2.2
charset-normalizer 3.3.2
Cython 3.0.8
durationpy 0.6
idna 3.6
numpy 1.26.4
opencv-python 4.9.0.80
pip 24.0
PyOpenGL 3.1.6
PyOpenGL-accelerate 3.1.6
python-dateutil 2.8.2
pyzed 1.3.0
requests 2.31.0
setuptools 58.1.0
six 1.16.0
urllib3 2.2.1
Within my Libs I have 2 folders that I can clearly see that are related to pyzed. 1. pyzed includes: sl_ai64.dll and sl_zed64.dll. 2. pyzed-1.3.0.dist-info has: INSTALLER, METADATA, RECORD, REQUESTED, top_level.txt and WHEEL. This is the error message:
(venv) PS C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024> python hello_zed.py
File “C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\hello_zed.py”, line 23, in
import pyzed.sl as sl
ModuleNotFoundError: No module named ‘pyzed.sl’; ‘pyzed’ is not a package
Output after I try to run the hello_zed.py script:
File “C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\hello_zed.py”, line 21, in
ModuleNotFoundError: No module named ‘pyzed’
(venv) PS C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\venv> python “C:\Program Files (x86)\ZED SDK\get_python_api.py”
→ Downloading to ‘C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\venv’
Detected platform:
win_amd64
Python 3.10
ZED SDK 4.0
→ Checking if https://download.stereolabs.com/zedsdk/4.0/whl/win_amd64/pyzed-4.0-cp310-cp310-win_amd64.whl exists and is available
→ Found ! Downloading python package into C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\venv\pyzed-4.0-cp310-cp310-win_amd64.whl
→ Installing necessary dependencies
Collecting numpy
Using cached numpy-1.26.4-cp310-cp310-win_amd64.whl.metadata (61 kB)
Using cached numpy-1.26.4-cp310-cp310-win_amd64.whl (15.8 MB)
Installing collected packages: numpy
Successfully installed numpy-1.26.4
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\venv\pyzed-4.0-cp310-cp310-win_amd64.whl
Collecting numpy>=1.13 (from pyzed==4.0)
Collecting cython>=3.0.0 (from pyzed==4.0)
Using cached Cython-3.0.8-cp310-cp310-win_amd64.whl.metadata (3.2 kB)
Using cached Cython-3.0.8-cp310-cp310-win_amd64.whl (2.8 MB)
Successfully installed cython-3.0.8 numpy-1.26.4 pyzed-4.0
Done
Installing OpenGL dependencies required to run the samples
→ Downloading PyOpenGL-3.1.6-cp310-cp310-win_amd64.whl
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\venv\pyopengl-3.1.6-cp310-cp310-win_amd64.whl
Installing collected packages: PyOpenGL
Successfully installed PyOpenGL-3.1.6
→ Downloading PyOpenGL_accelerate-3.1.6-cp310-cp310-win_amd64.whl
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\venv\pyopengl_accelerate-3.1.6-cp310-cp310-win_amd64.whl
Installing collected packages: PyOpenGL-accelerate
Successfully installed PyOpenGL-accelerate-3.1.6
Pyzed directory is c:\users\lasse\documents\stereovision\stereovisioncapstone2024\venv\lib\site-packages
ImportError: DLL load failed while importing sl: Määritettyä osaa ei löydy.
Inside workspace:
(venv) PS C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024> python “C:\Program Files (x86)\ZED SDK\get_python_api.py”
→ Downloading to ‘C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024’
Detected platform:
win_amd64
Python 3.10
ZED SDK 4.0
→ Found ! Downloading python package into C:\Users\lasse\Documents\StereoVision\StereoVisionCapstone2024\pyzed-4.0-cp310-cp310-win_amd64.whl
Collecting numpy
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\pyzed-4.0-cp310-cp310-win_amd64.whl
Done
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\pyopengl-3.1.6-cp310-cp310-win_amd64.whl
Processing c:\users\lasse\documents\stereovision\stereovisioncapstone2024\pyopengl_accelerate-3.1.6-cp310-cp310-win_amd64.whl
It will help you find out what DLL the pyzed module is trying to find. Then, you can find out exactly which one it can find, and which one it cannot.
Finally, you can add to your PATH the folder that is missing, or copy the DLLs into pyzed’s folder.
