Using a Gimbal with ZED-X Camera — Is It Supported and Recommended?
Hello everyone,
I recently purchased a ZED-X stereo camera and I am exploring options for mechanical stabilization.
My main question is whether a gimbal can be used effectively with the ZED-X, and if so, under what constraints.
More specifically, I would like to understand:
  • Is the ZED-X designed to be mounted on a gimbal, or is it expected to be rigidly mounted?
  • Are there known issues when using a gimbal with a stereo camera (e.g. rolling shutter effects, baseline distortion, synchronization, calibration drift)?
  • Does Stereolabs provide any official recommendations or best practices regarding gimbal usage?
  • Are there specific gimbal models or stabilization approaches (2-axis vs 3-axis, IMU-assisted, software stabilization) that work better with ZED-X?
  • How does gimbal motion interact with depth estimation, visual odometry, and SLAM in the ZED SDK?
My use case involves mobile / UAV-mounted perception, so vibration isolation and motion smoothness are important, but I want to avoid degrading stereo depth quality or breaking calibration assumptions.
If anyone has practical experience using ZED-X (or similar stereo rigs) on a gimbal, I’d really appreciate insights, pitfalls, or example setups.
Thanks in advance!
Hi @SergeyMalashenko
The ZED X camera has been designed targeting robotic applications, so it can work even if installed on a gimbal.
The ZED X has 2 Global Shutter CMOS sensors, so it’s not affected by this kinf of issues.
We do not have this information. Maybe other customers can share their experience.
A gimbal can compensate for camera self-rotation; the SLAM algorithm of the ZED SDK estimates camera ego-motion by using visual and inertial information. As long as the camera’s overall movements remain consistent with those of a robot, the SLAM results are unaffected.
Just an example, if a robot is rotating clockwise at 1 rad/sec and the gimbal compensates this movement, rotating the camera counterclockwise at 1 rad/sec, the SLAM algorithm will report 0 rad/sec as rotation speed, “thinking” that the robot is steady.
In this case, a good gimbal can only improve the final results, not degrade them.
