Update to sdk 4.1.1 and zed x camera locks up
I updated my orion nx box to sdk 4.1.1 I used the sdk for jetpack v 5.1.1 which is what my orion shipped with. Since doing the upgrade the as soon as I try any of the apps such as explorer, diagnostic, etc, the camera will work for maybe 40 frames or so and then lock up, and I have to restart to get to the same place but only get another 40 frames.
Any thoughts, do I need to upgrade firmware on the zed x camera? If so how do I do that given online it says I cant do it from sterolabs nx orion box, and I dont have a capture card on my computer with the appropriate connector.
Thanks
Hi @roundtire
please run the ZED Diagnostic tool and send me the report file it generates
As I am a new user the site will not let me upload files so I have attached the text. The text below is what occurs after I open explorer and the camera locks up and then I close explorer and open the diagnostic. I will post the diagnostic of before I open explorer in another reply thanks
“AI Models”: {
“info”: [
“NEURAL DEPTH is not optimized”,
“NEURAL PLUS DEPTH is not optimized”
“Camera Test”: {
“InternalDevicesCount”: 0,
“ZEDCount”: 1,
“camera”: {
“Device ID”: 0,
“Init Output”: “Error : Camera not found in system path”
“error”: [
“Camera already in use
Several program cannot use the ZED at the same time, make sure to close them.”
“sensors”: {
“Devices”: {
“CorruptedFirmware”: false,
“GMSL driver”: “ii stereolabs-zedx 1.0.2-LI-MAX96712-L4T35.3.1 arm64 NVIDIA Kernel DTB Modified Package by Stereolabs\n”,
“GMSL driver compatiblity”: “OK”,
“GMSLList”: [
“Serial”: “40306401”,
“Sub Model”: “ZED-XG 120mm”,
“id”: 0,
“path”: “/dev/i2c-30”,
“state”: “Not Available”
“USBList”: [
“USB_path”: “/2/4/3”,
“idProduct”: “0x6015”,
“idVendor”: “0x0403”
“USB_path”: “/2/4/2”,
“USB_path”: “/2/4/1”,
“idProduct”: “0x01a9”,
“idVendor”: “0x1546”
“USB_path”: “/2/4”,
“idProduct”: “0x0608”,
“idVendor”: “0x05e3”
“USB_path”: “/2/3”,
“idProduct”: “0x0029”,
“idVendor”: “0x8087”
“USB_path”: “/2/2”,
“idProduct”: “0x3700”,
“idVendor”: “0x0dd8”
“USB_path”: “/2/1”,
“idProduct”: “0xc52b”,
“idVendor”: “0x046d”
“USB_path”: “/2”,
“Graphics Card”: {
“deviceCount”: 1,
“deviceDriverVersion”: 11040,
“devices”: [
“arch”: “Ampere”,
“computeCapability”: “8.7”,
“cores”: 512,
“name”: “Orin”,
“totalMemoryBytes”: “16136392704”,
“totalMemoryMB”: 15388.86328125
“glx_info”: “OpenGL vendor string: NVIDIA Corporation\nOpenGL renderer string: NVIDIA Tegra Orin (nvgpu)/integrated\nOpenGL core profile version string: 4.6.0 NVIDIA 35.3.1\nOpenGL core profile shading language version string: 4.60 NVIDIA\nOpenGL core profile context flags: (none)\nOpenGL core profile profile mask: core profile\nOpenGL core profile extensions:\nOpenGL version string: 4.6.0 NVIDIA 35.3.1\nOpenGL shading language version string: 4.60 NVIDIA\nOpenGL context flags: (none)\nOpenGL profile mask: (none)\nOpenGL extensions:\nOpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 35.3.1\nOpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20\nOpenGL ES profile extensions:\n”,
“initResult”: 0,
“valid”: [
“Graphics card: Orin”
“Processor”: {
“L4T version”: “35.3.1”,
“OS”: "Ubuntu 20.04.5 LTS “,
“avxSupported”: false,
“coreCount”: “8”,
“cpu”: " ARMv8 Processor rev 1 (v8l)”,
“datetime”: “2024-05-09 05:39:25 PM”,
“hyperThreading”: “0”,
“motherboard”: “NVIDIA Orin NX Developer Kit, Unknown”,
“ramCapacity”: “16.136393”,
“ramUsage”: “”,
“ramUsed”: “3.062288”,
“threadCount”: “8”,
“valid”: [
“Processor: ARMv8 Processor rev 1 (v8l)”,
“Motherboard: NVIDIA Orin NX Developer Kit, Unknown”
“ZED SDK”: {
“CUDA Toolkit version”: “V11.4.315 -->located in /usr/local/cuda-11.4/bin/nvcc”,
“CUDA loading”: false,
“ZED SDK Version (Diag)”: “4.1.1”,
“ZED SDK Version (RT)”: “4.1.1”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 11040,
“cudnnCudartVersion”: 11040,
“cudnnVersion”: 8600,
“cudnnVersionExpected”: 8600,
“tensorVersion”: 8502
“binFiles”: [
“libsl_ai.so”,
“libsl_zed.so”,
“libsl_zed_static.a”
“resourcesFiles”: [
“neural_depth_3.6.model”,
“objects_accurate_3.2.model”,
“objects_medium_3.2.model”,
“objects_performance_3.2.model”,
“person_head_accurate_2.4.model”,
“person_head_performance_2.4.model”,
“person_reid_1.4.model”,
“skeleton_body18_3.2.model”,
“skeleton_body38_3.5.model”
“resourcesFilesExpected”: [
“objects_performance_3.2”
“valid”: [
“ZED SDK version: 4.1.1”,
“CUDA version: V11.4.315”
“AI Models”: {
“info”: [
“Camera Test”: {
“ZEDCount”: 1,
“camera”: {
“Device ID”: 0,
“Firmware”: 2001,
“Init Output”: “OK”,
“Model”: “ZED-X”,
“Serial Number”: 40306401,
“valid”: [
“Camera: ZED-X”,
“Firmware: 2001”
“resolutions”: {
“HD1200@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“height (input)”: 1200,
“height (output)”: 1200,
“initialization”: “OK”,
“status”: true,
“width (input)”: 1920,
“width (output)”: 1920
“HD1200@60”: {
“fps (input)”: 60,
“fps (output)”: 60,
“status”: true,
“SVGA@120”: {
“fps (input)”: 120,
“fps (output)”: 120,
“height (input)”: 600,
“height (output)”: 600,
“status”: true,
“width (input)”: 960,
“width (output)”: 960
“sensors”: {
“Devices”: {
“GMSLList”: [
“id”: 0,
“state”: “Available”
“USBList”: [
“USB_path”: “/2/4”,
“USB_path”: “/2/3”,
“USB_path”: “/2/2”,
“USB_path”: “/2/1”,
“USB_path”: “/2”,
“Graphics Card”: {
“deviceCount”: 1,
“devices”: [
“arch”: “Ampere”,
“cores”: 512,
“name”: “Orin”,
“initResult”: 0,
“valid”: [
“Processor”: {
“coreCount”: “8”,
“datetime”: “2024-05-09 05:37:18 PM”,
“ramUsage”: “”,
“ramUsed”: “2.147222”,
“threadCount”: “8”,
“valid”: [
“ZED SDK”: {
“ai”: {
“checkAI”: true,
“binFiles”: [
“libsl_ai.so”,
“libsl_zed.so”,
“resourcesFiles”: [
“valid”: [
Hi @roundtire
I noticed that you are using a peculiar configuration.
Please send an email to support@stereolabs.com.
Please add the dmesg.log report file and a detailed description of the Jetson system that you are using:
  • Jetson module
  • carrier board model
  • GMSL2 capture card model
