I am a student using the ZED 2i for a robotics project. I would like to modify the spatial mapping example to output a fused point cloud (.ply) instead of a mesh. This is the modification I have done on the C example. The device is a Jetson Nano with the [ZED SDK for L4T 32.7 (Jetpack 4.6.X)] installed.
All i changed was the very bottom where I now save point cloud instead of mesh. What I get is a blank .ply file with just the header information.
Thank you in advance and for your patience, I know this is definitely something simple I am overlooking.
- Author : Josef Miller
- Date : 2/17/2023
- Project : Control_System
- Device : Tegra X1 SoC
- Software : Visual Studio Code
- Compiler : ???
- C Dialect : ???
#include <sl/c_api/zed_interface.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#define FRAME_COUNT 20
int main()
int camera_id = 0;
sl_create_camera(camera_id);
struct SL_InitParameters init_param;
init_param.input_type = SL_INPUT_TYPE_USB;
init_param.resolution = SL_RESOLUTION_HD720;
init_param.camera_fps = 30;
init_param.camera_device_id = camera_id;
init_param.camera_image_flip = SL_FLIP_MODE_AUTO;
init_param.camera_disable_self_calib = false;
init_param.enable_right_side_measure = false;
init_param.svo_real_time_mode = true;
init_param.depth_mode = SL_DEPTH_MODE_PERFORMANCE;
init_param.depth_stabilization = 1;
init_param.depth_minimum_distance = 0;
init_param.depth_maximum_distance = 40;
init_param.coordinate_unit = SL_UNIT_METER;
init_param.coordinate_system = SL_COORDINATE_SYSTEM_RIGHT_HANDED_Z_UP_X_FWD;
init_param.sdk_gpu_id = -1;
init_param.sdk_verbose = true;
init_param.sensors_required = false;
init_param.enable_image_enhancement = false;
init_param.open_timeout_sec = 0;
if (sl_open_camera(camera_id, &init_param, "", "", 0, "", "", "") == SL_ERROR_CODE_FAILURE)
printf("Error Open \n");
return SL_ERROR_CODE_FAILURE;
struct SL_Vector3 position = {.x = 0, .y = 0, .z = 0};
struct SL_Quaternion rotation = {.x = 0, .y = 0, .z = 0, .w = 1};
struct SL_PositionalTrackingParameters tracking_param;
tracking_param.initial_world_rotation = rotation;
tracking_param.initial_world_position = position;
tracking_param.enable_area_memory = true;
tracking_param.enable_pose_smothing = false;
tracking_param.set_floor_as_origin = false;
tracking_param.set_as_static = false;
tracking_param.enable_imu_fusion = true;
tracking_param.depth_min_range = -1;
tracking_param.set_gravity_as_origin = true;
if (sl_enable_positional_tracking(camera_id, &tracking_param, "") == SL_ERROR_CODE_FAILURE)
printf("Error Enable Positional Tracking \n");
struct SL_SpatialMappingParameters mapping_param;
mapping_param.resolution_meter = 0.05f;
mapping_param.range_meter = 0;
mapping_param.save_texture = false;
mapping_param.use_chunk_only = true;
mapping_param.max_memory_usage = 2048;
mapping_param.reverse_vertex_order = false;
mapping_param.map_type = SL_SPATIAL_MAP_TYPE_FUSED_POINT_CLOUD;
if (sl_enable_spatial_mapping(camera_id, &mapping_param) == SL_ERROR_CODE_FAILURE)
printf("Error Enable Spatial Mapping \n");
struct SL_RuntimeParameters rt_param;
rt_param.sensing_mode = SL_SENSING_MODE_STANDARD;
rt_param.reference_frame = SL_REFERENCE_FRAME_CAMERA;
rt_param.enable_depth = true;
rt_param.confidence_threshold = 100;
rt_param.texture_confidence_threshold = 100;
rt_param.remove_saturated_areas = true;
int width = sl_get_width(camera_id);
int height = sl_get_height(camera_id);
enum SL_SPATIAL_MAPPING_STATE map_state;
for (int i = 1; i <= FRAME_COUNT; ++i)
if (sl_grab(camera_id, &rt_param) == SL_ERROR_CODE_SUCCESS)
map_state = sl_get_spatial_mapping_state(camera_id);
printf("\r Images captured: %i || Spatial mapping state : %i \t \n", i, map_state);
printf("Extracting spatial map...\n");
sl_extract_whole_spatial_map(camera_id);
printf("Saving point cloud ... \n");
sl_save_point_cloud(camera_id, "cloud.ply", SL_MESH_FILE_FORMAT_PLY);
sl_disable_spatial_mapping(camera_id);
sl_disable_positional_tracking(camera_id, "");
sl_close_camera(camera_id);
return 0;
