Unity ScriptableRenderContext Error when trying example scene
I am following the getting started with Unity instructions and when I try to run an example scene I get the following error:
Assets\ZED\SDK\Helpers\Scripts\MR\ZEDMixedRealityPlugin.cs(662,32): error CS0246: The type or namespace name ‘ScriptableRenderContext’ could not be found (are you missing a using directive or an assembly reference?)
Any help is appreciated.
Hi @delucr, welcome to the forums
There is indeed an using UnityEngine.Rendering; missing.
Please add it manually at the top of the Assets\ZED\SDK\Helpers\Scripts\MR\ZEDMixedRealityPlugin.cs script, it should work.
We’ll fix this oversight in the next release (we don’t dev with the URP on enough, it seems :sweat: )
Best,
Jean-Loup
Thanks Jean-Loup!
That worked. I appreciate the help.
-Rich
