Unable to Complete ZED SDK Installation Due to Missing Shared Library
When installing the ZED SDK, I chose to download the depth model and all models, but the installation was unsuccessful. The following error appeared:
/usr/local/zed/tools/ZED_Diagnostic: error while loading shared libraries: libcudart.so.12: cannot open shared object file: No such file or directory
I have included more detailed error information below. Could you please advise me on how to resolve this issue? Thank you very much!
ray@jetson:~/Downloads$ ./ZED_SDK_Tegra_L4T36.4_v5.0.3.zstd.run
Verifying archive integrity...  100%   MD5 checksums are OK. All good.
Uncompressing 'ZED camera SDK by Stereolabs (Use 'sudo apt install zstd' if zstd is not found)'  100%
L4T version 36.4 detected. OK
To continue you have to accept the EULA. Accept  [Y/n] ?y
Installing...
ZED SDK will be installed in: /usr/local/zed
[sudo] password for ray:
Sorry, try again.
Checking CUDA version...
ERROR : the installer failed to detect the CUDA version (CUDA 12.6 required), make sure it's installed
Do you want to install CUDA 12.6 automatically [Y/n] ?n
The ZED SDK will NOT work without CUDA, Continue  [Y/n] ?y
Installing...
Install samples (recommended) [Y/n] ?y
Installation path: /usr/local/zed/samples/
Dependencies installation complete
Do you want to install the Python API (recommended) [Y/n] ?y
Please specify your python executable: python3
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
Requirement already satisfied: numpy in /home/ray/.local/lib/python3.10/site-packages (2.2.6)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.25.1)
-> Downloading to '/tmp/selfgz12350'
Detected platform:
         linux_aarch64
         Python 3.10
         ZED SDK 5.0
-> Checking if https://download.stereolabs.com/zedsdk/5.0/whl/linux_aarch64/pyzed-5.0-cp310-cp310-linux_aarch64.whl exists and is available
-> Found ! Downloading python package into /tmp/selfgz12350/pyzed-5.0-cp310-cp310-linux_aarch64.whl
-> Installing necessary dependencies
Requirement already satisfied: wheel in /usr/lib/python3/dist-packages (0.37.1)
Requirement already satisfied: cython in /home/ray/.local/lib/python3.10/site-packages (3.1.2)
Processing ./pyzed-5.0-cp310-cp310-linux_aarch64.whl
Collecting cython>=3.0.0
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/23/3a/5b92bfff9c1cc1179a493684d0e6a893ee7cd69c4f1977813000ea76c5d7/cython-3.1.2-cp310-cp310-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (3.2 MB)
Collecting numpy<3.0,>=2.0
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/eb/17/96a3acd228cec142fcb8723bd3cc39c2a474f7dcf0a5d16731980bcafa95/numpy-2.2.6-cp310-cp310-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (14.3 MB)
  Attempting uninstall: numpy
    Found existing installation: numpy 2.2.6
    Uninstalling numpy-2.2.6:
      Successfully uninstalled numpy-2.2.6
  Attempting uninstall: cython
    Found existing installation: Cython 3.1.2
    Uninstalling Cython-3.1.2:
      Successfully uninstalled Cython-3.1.2
  Attempting uninstall: pyzed
    Found existing installation: pyzed 5.0
    Uninstalling pyzed-5.0:
      Successfully uninstalled pyzed-5.0
Successfully installed cython-3.1.2 numpy-2.2.6 pyzed-5.0
Done
  To install it later or on a different environment run :
 python -m pip install --ignore-installed /tmp/selfgz12350/pyzed-5.0-cp310-cp310-linux_aarch64.whl
The ZED Python API was installed for 'python3'
/sbin/ldconfig.real: /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so is not a symbolic link
Do you want to download and optimize the NEURAL Depth models now? These will be required at runtime and will be processed then if not done now, which will extend startup time on first use. [Y/n] ?y
Do you want to run the ZED Diagnostic to download all AI models [Y/n] ?y
Do you want to run the ZED Diagnostic to optimize all AI models, it may take a very long time, up to multiple hours but will be done only once. Otherwise it will be optimized just in time when running the ZED SDK [Y/n] ?y
For GMSL support, please navigate to https://www.stereolabs.com/docs/get-started-with-zed-x/ where you will find compatible drivers and installation instructions.
Please note that installing the 'libv4l-dev' apt package at any point on jetson will break the hardware encoding/decoding support
ZED SDK installation complete, with 1 warning(s)
ray@jetson:~/Downloads$ apt list libv4l-dev
Listing... Done
ray@jetson:~/Downloads$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan  8 01:49:37 UTC 2025
# KERNEL_VARIANT: oot
ray@jetson:~/Downloads$ nvidia-smi
Mon Jul  7 18:04:58 2025
| NVIDIA-SMI 540.4.0                Driver Version: 540.4.0      CUDA Version: 12.6     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Orin (nvgpu)                  N/A  | N/A              N/A |                  N/A |
| N/A   N/A  N/A               N/A /  N/A | Not Supported        |     N/A          N/A |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
Hi @eatpockyboy
Is this a freshly flashed Jetson device?
Have you installed the Jetpack SDK packages before installing the ZED SDK?
sudo apt update && sudo apt install nvidia-jetpack
@Myzhar Thank you for your attention. I encountered an error while running “sudo apt update && sudo apt install nvidia-jetpack.” The error message is as follows:
ray@jetson:~/Downloads$ sudo apt update && sudo apt install nvidia-jetpack
Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [129 kB]
Hit:3 https://repo.download.nvidia.cn/jetson/common r36.4 InRelease
Hit:4 https://repo.download.nvidia.cn/jetson/t234 r36.4 InRelease
Hit:5 https://repo.download.nvidia.cn/jetson/ffmpeg r36.4 InRelease
Fetched 129 kB in 2s (66.7 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
12 packages can be upgraded. Run 'apt list --upgradable' to see them.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 nvidia-jetpack-dev : Depends: nvidia-vpi-dev (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-cuda-dev (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-tensorrt-dev (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-nsight-systems (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-cudnn-dev (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-nsight-graphics (= 6.2+b77) but 6.2.1+b38 is to be installed
                      Depends: nvidia-opencv-dev (= 6.2+b77) but it is not going to be installed
 nvidia-jetpack-runtime : Depends: nvidia-cuda (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-tensorrt (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-container (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-cupva (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-opencv (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-cudnn (= 6.2+b77) but 6.2.1+b38 is to be installed
                          Depends: nvidia-vpi (= 6.2+b77) but 6.2.1+b38 is to be installed
E: Unable to correct problems, you have held broken packages.
What NVIDIA model are you using?
How did you flash it?
Thank you very much @Myzhar . I first tried uninstalling all the old systems, and then reflashing the system with JetPack 6.2 resolved the issue. This topic can be closed.
