The sdk you have for ubuntu, will it be able to run on arch linux?
I am not sure if the ubuntu version of the zed sdk that it will be able to run on arch linux distros ?
my PC’s distro is Endeavour Os. So can anyone say if this software will run on my machine ?
Thanks in Advance
If you’re able to run CUDA application with your distribution then It should work. You will have to install the dependencies at the correct version by yourself though. For the ZED SDK libraries, it should be mostly fine but the tools may be trickier.
You can inspect the installer script by deflating the installer like this:
./ZED_SDK_installer.sh --noexec --target installer_content
It will write the installer content into the folder “installer_content”, the install script is linux_installer_release.sh. You can then see the dependencies list, tweak commands, etc. Please be aware that we don’t provide support for distribution other than Ubuntu.
Another solution would be to use docker:
Sorry, I know this is an old thread, but I came here originally via web search, so I figure others looking for a solution to this will too.
I have pushed the zed-sdk-bin package to the Arch Linux AUR. It took quite a lot of fiddling to get it to behave, but I think it’s ready to share now.
It’s working well in my testing now, but I will be continuing serious testing over the next few weeks, putting it through its paces.
I’m using a ZED 2i camera.
