Hello, I used spatial mapping to generate a fused point cloud, but I found that the generated result is not very clear. How can I adjust the parameters to make the generated point cloud clearer. I have changed the resolution of the mapping to high
// Copyright (c) 2024, STEREOLABS.
// All rights reserved.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// “AS IS” AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
** This sample demonstrates how to capture a live 3D reconstruction of a scene **
** as a fused point cloud and display the result in an OpenGL window. **
// ZED includes
#include <sl/Camera.hpp>
// Sample includes
#include “GLViewer.hpp”
#include <opencv2/opencv.hpp>
// Using std and sl namespaces
using namespace std;
using namespace sl;
//#define BUILD_MESH 1
void parse_args(int argc, char **argv,InitParameters& param, sl::Mat &roi);
void print(std::string msg_prefix, sl::ERROR_CODE err_code = sl::ERROR_CODE::SUCCESS, std::string msg_suffix = “”);
Camera zed;
// Set configuration parameters for the ZED
init_parameters.depth_mode = DEPTH_MODE::NEURAL;//深度计算模式 可调
init_parameters.coordinate_units = UNIT::METER;
init_parameters.coordinate_system = COORDINATE_SYSTEM::RIGHT_HANDED_Y_UP; // OpenGL's coordinate system is right_handed
init_parameters.depth_maximum_distance = 8.;//最大深度
sl::Mat roi;
parse_args(argc, argv, init_parameters, roi);
// Open the camera
if (returned_state != ERROR_CODE::SUCCESS) {// Quit if an error occurred
print("Open Camera", returned_state, "\nExit program.");
zed.close();
return EXIT_FAILURE;
if(roi.isInit()){
auto state = zed.setRegionOfInterest(roi, {sl::MODULE::POSITIONAL_TRACKING, sl::MODULE::SPATIAL_MAPPING});
std::cout<<"Applied ROI "<<state<<"\n";
/* Print shortcuts*/
std::cout<<"Shortcuts\n";
std::cout<<"\t- 'l' to enable/disable current live point cloud display\n";
std::cout<<"\t- 'w' to switch mesh display from faces to triangles\n";
std::cout<<"\t- 'd' to switch background color from dark to light\n";
auto camera_infos = zed.getCameraInformation();
// Setup and start positional tracking
Pose pose;
POSITIONAL_TRACKING_STATE tracking_state = POSITIONAL_TRACKING_STATE::OFF;
returned_state = zed.enablePositionalTracking();
print("Enabling positional tracking failed: ", returned_state);
zed.close();
// Set spatial mapping parameters
SpatialMappingParameters spatial_mapping_parameters;
// Request a Point Cloud
#if BUILD_MESH
spatial_mapping_parameters.map_type = SpatialMappingParameters::SPATIAL_MAP_TYPE::MESH;
Mesh map;
#else
spatial_mapping_parameters.map_type = SpatialMappingParameters::SPATIAL_MAP_TYPE::FUSED_POINT_CLOUD;
FusedPointCloud map;
#endif
// Set mapping range, it will set the resolution accordingly (a higher range, a lower resolution)
spatial_mapping_parameters.set(SpatialMappingParameters::MAPPING_RANGE::MEDIUM);
spatial_mapping_parameters.set(SpatialMappingParameters::MAPPING_RESOLUTION::HIGH);
// Request partial updates only (only the last updated chunks need to be re-draw)
spatial_mapping_parameters.use_chunk_only = true;
// Stability counter defines how many times a stable 3D points should be seen before it is integrated into the spatial mapping
spatial_mapping_parameters.stability_counter = 4;
// Timestamp of the last fused point cloud requested
chrono::high_resolution_clock::time_point ts_last;
// Setup runtime parameters
RuntimeParameters runtime_parameters;
// Use low depth confidence to avoid introducing noise in the constructed model
runtime_parameters.confidence_threshold = 50;
runtime_parameters.texture_confidence_threshold = 100;
auto resolution = camera_infos.camera_configuration.resolution;
// Define display resolution and check that it fit at least the image resolution
float image_aspect_ratio = resolution.width / (1.f * resolution.height);
int requested_low_res_w = min(1080, (int)resolution.width);
sl::Resolution display_resolution(requested_low_res_w, requested_low_res_w / image_aspect_ratio);
Mat image(display_resolution, MAT_TYPE::U8_C4, sl::MEM::GPU);
Mat point_cloud(display_resolution, MAT_TYPE::F32_C4, sl::MEM::GPU);
// Point cloud viewer
GLViewer viewer;
viewer.init(argc, argv, image, point_cloud, zed.getCUDAStream());
bool request_new_mesh = true;
bool wait_for_mapping = true;
sl::Timestamp timestamp_start;
timestamp_start.data_ns = 0;
int i = 0;
// Start the main loop
while (viewer.isAvailable()) {
// Grab a new image
if (zed.grab(runtime_parameters) == ERROR_CODE::SUCCESS)
// Retrieve the left image
zed.retrieveImage(image, VIEW::LEFT, MEM::GPU, display_resolution);
zed.retrieveMeasure(point_cloud, MEASURE::XYZBGRA, MEM::GPU, display_resolution);
// Retrieve the camera pose data
tracking_state = zed.getPosition(pose);
viewer.updateCameraPose(pose.pose_data, tracking_state);
if (tracking_state == POSITIONAL_TRACKING_STATE::OK) {
if(wait_for_mapping){
zed.enableSpatialMapping(spatial_mapping_parameters);
wait_for_mapping = false;
}else{
if(request_new_mesh){
auto duration = chrono::duration_cast<chrono::milliseconds>(chrono::high_resolution_clock::now() - ts_last).count();
// Ask for a fused point cloud update if 500ms have elapsed since last request
if(duration > 100) {
// Ask for a point cloud refresh
zed.requestSpatialMapAsync();
request_new_mesh = false;
// If the point cloud is ready to be retrieved
if(zed.getSpatialMapRequestStatusAsync() == ERROR_CODE::SUCCESS && !request_new_mesh) {
zed.retrieveSpatialMapAsync(map);
viewer.updateMap(map);
ts_last = chrono::high_resolution_clock::now();
// press "esc" to save generated point cloud
map.save("MyMap-2", sl::MESH_FILE_FORMAT::PLY);
printf("point cloud saved successed");
// Free allocated memory before closing the camera
image.free();
point_cloud.free();
// Close the ZED
zed.close();
return 0;
if(argc == 1) return;
for(int id = 1; id < argc; id ++) {
std::string arg(argv[id]);
if(arg.find(“.svo”)!=string::npos) {
// SVO input mode
param.input.setFromSVOFile(arg.c_str());
param.svo_real_time_mode=true;
cout<<"[Sample] Using SVO File input: "<<arg<<endl;
unsigned int a,b,c,d,port;
if (sscanf(arg.c_str(),"%u.%u.%u.%u:%d", &a, &b, &c, &d,&port) == 5) {
// Stream input mode - IP + port
string ip_adress = to_string(a)+"."+to_string(b)+"."+to_string(c)+"."+to_string(d);
param.input.setFromStream(String(ip_adress.c_str()),port);
cout<<"[Sample] Using Stream input, IP : "<<ip_adress<<", port : "<<port<<endl;
else if (sscanf(arg.c_str(),"%u.%u.%u.%u", &a, &b, &c, &d) == 4) {
// Stream input mode - IP only
param.input.setFromStream(String(argv[1]));
cout<<"[Sample] Using Stream input, IP : "<<argv[1]<<endl;
else if (arg.find("HD2K") != string::npos) {
param.camera_resolution = RESOLUTION::HD2K;
cout << "[Sample] Using Camera in resolution HD2K" << endl;
}else if (arg.find("HD1200") != string::npos) {
param.camera_resolution = RESOLUTION::HD1200;
cout << "[Sample] Using Camera in resolution HD1200" << endl;
} else if (arg.find("HD1080") != string::npos) {
param.camera_resolution = RESOLUTION::HD1080;
cout << "[Sample] Using Camera in resolution HD1080" << endl;
} else if (arg.find("HD720") != string::npos) {
param.camera_resolution = RESOLUTION::HD720;
cout << "[Sample] Using Camera in resolution HD720" << endl;
}else if (arg.find("SVGA") != string::npos) {
param.camera_resolution = RESOLUTION::SVGA;
cout << "[Sample] Using Camera in resolution SVGA" << endl;
}else if (arg.find("VGA") != string::npos) {
param.camera_resolution = RESOLUTION::VGA;
cout << "[Sample] Using Camera in resolution VGA" << endl;
}else if ((arg.find(".png") != string::npos) || ((arg.find(".jpg") != string::npos))) {
roi.read(arg.c_str());
cout << "[Sample] Using Region of intererest from "<< arg << endl;
void print(std::string msg_prefix, sl::ERROR_CODE err_code, std::string msg_suffix) {
cout <<“[Sample]”;
if (err_code != sl::ERROR_CODE::SUCCESS)
cout << "[Error] “;
else
cout<<” ";
cout << msg_prefix << " ";
if (err_code != sl::ERROR_CODE::SUCCESS) {
cout << " | " << toString(err_code) << " : ";
cout << toVerbose(err_code);
if (!msg_suffix.empty())
cout << " " << msg_suffix;
cout << endl;
