Technical Details of ZED mini & ZED 2i
After checking the Datasheet/Specifications of the USB camera Solutions (ZED mini & ZED 2i), I am not confident in the following information relevant for my application:
  • Does the camera provide separate data streams for 2D RGB images and 3D depth data? In particular, is it possible to operate the device purely as a 2D RGB camera if required?
  • Do the cameras support auto-focus functionality?
  • Is the ZED Mini compatible with Windows 11, or are there known limitations regarding this operating system?
Thank you for clarification!
Hi @spem
Yes, it’s possible. I recommend you explore the online documentation for details.
All the cameras have fixed focus that is factory calibrated.
It’s 100% compatible with Windows 11.
