svo file Playback error
Getting the following error while running svo_playback.py.Same error using C++ file as well.
[ERROR] (../src/sl_input/mmapi/R382/NvV4l2ElementPlane.cpp:370) <p�}> Capture Plane:Getting format: failed: Invalid argument
Traced back the error to the following line input_type.set_from_svo_file(filepath)
svo file recorded using zed 2i NVIDIA Jetson Thor.
Hi @anjan_pivotal
What’s the output of the command ZED_SVO_Editor -inf <svo_filename>?
