I have svo files which are corrupted. I have tried repairing the files using the ZED SVO Editor but the files remains unrepaired, and same size without opening up.
Are there other options to get these svo files repaired.
Hi @Abideen,
We currently have a few issues with SVO2 files and Windows, we are currently preparing a fix for the next patch of the ZED SDK which resolves this issue.
To give more context, we are running the video recording from a windows PC and recording svo files and not SVO2.
The corrupted files originally comes at 1GB and the repaired files which fails to open too comes at the same file size.
Hi @Abideen,
What version of the ZED SDK are you using? If the version is >= 4.1, you are most likely saving SVO2 files.
If you confirm you are saving as a SVO1, would it be possible for you to share the file so we can investigate?
Hi @mattrouss ,
I have sent you a copy of the files via email. Could you please have a look at it.
Thank you for your help.
