Streaming synchronized stereo (ZED) from Nano to AGX over Ethernet — latency concerns
I’m working on a robotics system using 2 ZED cameras with hard trigger + strobe lighting connected to a ZED Box Mini Nano.
The issue is compute — the Nano is not sufficient for VIO + detection workloads.
I’m considering the following architecture:
  • ZED Box Mini Nano handles camera interfacing + sync
  • Stream data over Ethernet to a Jetson AGX (non-dev kit, rugged carrier board)
  • Run VIO + detection on AGX
  • Send outputs to an embedded controller for actuation
I explored using a quad deserializer directly with AGX, but it seems to only be supported on dev kits, and those are currently unavailable. We need to use a rugged AGX carrier board with more I/O.
Is this a reasonable architecture for low-latency robotics applications
Yes, this is a working pipeline.
Have you considered using one of the solutions provided by our partners?
