I have a few questions and would appreciate detailed assistance with each:
Streaming Setup: I have two ZED 2i cameras connected to a Jetson Orin AGX. If I want to stream video from both of the cameras to my laptop at HD720 resolution, what is the maximum frame rate I can achieve for each camera? Is it 30 FPS or 60 FPS? Additionally, will the frame rate remain consistent if I stream from both cameras simultaneously?
Saving Depth Maps: I plan to save depth maps on a second Jetson device on the same local network. Will the number of frames saved be the same as the number of frames displayed, or can I specify a different rate for saving depth maps? If it’s possible to save depth maps at a different rate, please provide guidance on how to achieve this.
FPS Reporting: When using
zed.get_current_fps, I receive results in fractions of a second rather than whole seconds. For example, at 30 FPS, the value should represent 1 second, but I get updates more frequently. Can you explain why this happens and how to interpret these results? -
Depth Map Saving: Is there a function in the ZED SDK to determine the number of depth maps saved per second? Also, what is the best file format for saving depth maps?
Can you recommend best BITRATE for each camera please ?
Thank you in advance for your help.
