when trying to launch streaming (using cpp samples script or ROS2) from a jetson orin nano with 5.0.1 sdk version installed the following error appears:
./ZED_Streaming_Sender
[2025-07-09 11:28:25 UTC][ZED][INFO] Logging level INFO
[2025-07-09 11:28:26 UTC][ZED][INFO] Using USB input… Switched to default resolution HD720
[2025-07-09 11:28:26 UTC][ZED][INFO] [Init] Health check functionality is limited when DEPTH_MODE::NONE is enabled, as it relies on the depth pipeline for image processing.
[2025-07-09 11:28:26 UTC][ZED][INFO] [Init] Depth mode: NONE
[2025-07-09 11:28:27 UTC][ZED][INFO] [Init] Camera successfully opened.
[2025-07-09 11:28:27 UTC][ZED][INFO] [Init] Camera FW version: 1523
[2025-07-09 11:28:27 UTC][ZED][INFO] [Init] Video mode: HD720@30
[2025-07-09 11:28:27 UTC][ZED][INFO] [Init] Serial Number: S/N XXXXXXX
[Streaming] Use Transport layer mode : 0
[ZED][Encoding] Critical Error : No Video Enc [enc_0]
[ZED][Streaming] Failed to create encoder [0.0] at resolution 1280x720
[2025-07-09 11:28:27 UTC][ZED][ERROR] [Streaming] Cannot enable streaming: Err Code -4
[Sample][Error] Streaming initialization error: | NO GPU COMPATIBLE : An NVIDIA GPU (Pascal or newer) is required to run this software (for Kepler and Maxwell GPU, please use CUDA 10.2 ZED SDK installers)
