I am using ZED 2i(4mm Focal length).
I have question of the specification.
- Vertical angular resolution
- Horizontal angular resolution
- max range
- min range
Thank you.
Thank you.
Hi @LeeHyokBeen
please refer to the information available on the camera datasheet.
Thank you for your response.
I have already checked the datasheet.
But the point cloud doesn’t have an angular resolution (1k or 2k).
So I’m calculating to get the horizontal angular resolution by dividing the horizontal FOV by the number of pixels.
Is this correct?
Thanks.
Yes, this is the correct method
