Set_floor_as_origin Failure
When I set_floor_as_origin = True, I often get this failure:
Camera opened successfully
Enabling Positional Tracking...
Positional Tracking enabled successfully
Initializing Camera Parameters...
Resolution: 1280x720
Focal length: fx=519.67, fy=519.67
HFOV: 101.85 degrees
VFOV: 69.42 degrees
Topdown FOV: 101.85 degrees++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
Initializing Runtime Parameters...
Initializing Obstacle Map...
Enable positional tracking : FAILURE. Exit program.
[2025-11-21 01:47:42 UTC][ZED][ERROR] Cannot use Spatial mapping: Positional tracking not enabled
I follow the example here:
    init_params.depth_mode = sl.DEPTH_MODE.NEURAL
    init_params.coordinate_units = sl.UNIT.METER  # Set units in meters
    init_params.coordinate_system = sl.COORDINATE_SYSTEM.RIGHT_HANDED_Z_UP_X_FWD
    init_params.depth_maximum_distance = 8.
    parse_args(args, init_params)
        print("Camera Open : "+repr(status)+". Exit program.")
        exit()
    print("Camera opened successfully")
    ## Enable positional tracking
    print("Enabling Positional Tracking...")
    # positional_tracking_parameters.set_floor_as_origin = True
    returned_state = zed.enable_positional_tracking(positional_tracking_parameters)
    if returned_state != sl.ERROR_CODE.SUCCESS:
        print("Enable Positional Tracking : "+repr(returned_state)+". Exit program.")
        exit()
    print("Positional Tracking enabled successfully")
Hi @Yixun-Hu
What ZED SDK version are you using?
I am using ZED SDK for JetPack 5.1.2 (L4T 35.4) 5.0 (Jetson Xavier, Orin AGX/NX/Nano, CUDA 11.4) on Jetson Orin NX 16GB, ubuntu 20.04.
Please upgrade the ZED SDK to the latest v5.1.1:
