Hi Myzhar,
Thanks for your quick reply! Here is the content of my common_stereo.yaml:
config/common_stereo.yaml
Common parameters to Stereolabs ZED Stereo cameras
ros__parameters:
use_sim_time: false # Set to true only if there is a publisher for the simulated clock to the /clock topic. Normally used in simulation mode.
simulation:
sim_address: '127.0.0.1' # The connection address of the simulation server. See the documentation of the supported simulation plugins for more information.
svo:
use_svo_timestamps: true # Use the SVO timestamps to publish data. If false, data will be published at the system time.
publish_svo_clock: false # [overwritten by launch file options] When use_svo_timestamps is true allows to publish the SVO clock to the `/clock` topic. This is useful for synchronous rosbag playback.
svo_loop: false # Enable loop mode when using an SVO as input source. NOTE: ignored if SVO timestamping is used
svo_realtime: false # if true the SVO will be played trying to respect the original framerate eventually skipping frames, otherwise every frame will be processed respecting the `pub_frame_rate` setting
general:
camera_timeout_sec: 5
camera_max_reconnect: 5
camera_flip: false
self_calib: true # Enable the self-calibration process at camera opening. See https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#affeaa06cfc1d849e311e484ceb8edcc5
serial_number: 0 # overwritten by launch file
pub_resolution: 'NATIVE' # The resolution used for image and depth map publishing. 'NATIVE' to use the same `general.grab_resolution` - `CUSTOM` to apply the `general.pub_downscale_factor` downscale factory to reduce bandwidth in transmission
pub_frame_rate: 30.0 # [DYNAMIC] Frequency of publishing of visual images and depth data (not the Point Cloud, see 'depth.point_cloud_freq'). This value must be equal or less than the camera framerate.
enable_image_validity_check: 1 # [SDK5 required] Sets the image validity check. If set to 1, the SDK will check if the frames are valid before processing.
gpu_id: -1
optional_opencv_calibration_file: '' # Optional path where the ZED SDK can find a file containing the calibration information of the camera computed by OpenCV. Read the ZED SDK documentation for more information: https://www.stereolabs.com/docs/api/structsl_1_1InitParameters.html#a9eab2753374ef3baec1d31960859ba19
async_image_retrieval: false # If set to true will camera image retrieve at a framerate different from \ref grab() application framerate. This is useful for recording SVO or sending camera stream at different rate than application.
publish_status: true # Advertise the status topics that are published only if a node subscribes to them
# Other parameters are defined, according to the camera model, in the 'zed.yaml', 'zedm.yaml', 'zed2.yaml', 'zed2i.yaml'
# 'zedx.yaml', 'zedxmini.yaml', 'virtual.yaml' files
video:
saturation: 4 # [DYNAMIC]
sharpness: 4 # [DYNAMIC]
gamma: 8 # [DYNAMIC]
exposure: 80 # [DYNAMIC]
gain: 80 # [DYNAMIC]
whitebalance_temperature: 42 # [DYNAMIC] - [28,65] x100 - works only if `auto_whitebalance` is false
publish_rgb: true # Advertise the RGB image topics that are published only if a node subscribes to them
publish_left_right: false # Advertise the left and right image topics that are published only if a node subscribes to them
publish_raw: false # Advertise the raw image topics that are published only if a node subscribes to them
publish_gray: false # Advertise the gray image topics that are published only if a node subscribes to them
publish_stereo: false # Advertise the stereo image topic that is published only if a node subscribes to it
sensors:
publish_imu_tf: false # [overwritten by launch file options] enable/disable the IMU TF broadcasting
sensors_pub_rate: 100. # frequency of publishing of sensors data. MAX: 400. - MIN: grab rate
publish_imu: false # Advertise the IMU topic that is published only if a node subscribes to it
publish_imu_raw: false # Advertise the raw IMU topic that is published only if a node subscribes to it
publish_cam_imu_transf: false # Advertise the CAMERA-IMU transformation topic that is published only if a node subscribes to it
publish_mag: false # Advertise the magnetometer topic that is published only if a node subscribes to it
publish_baro: false # Advertise the barometer topic that is published only if a node subscribes to it
publish_temp: false # Advertise the temperature topics that are published only if a node subscribes to them
region_of_interest:
automatic_roi: false # Enable the automatic ROI generation to automatically detect part of the robot in the FoV and remove them from the processing. Note: if enabled the value of `manual_polygon` is ignored
#manual_polygon: '[[0.25,0.33],[0.75,0.33],[0.75,0.5],[0.5,0.75],[0.25,0.5]]' # A polygon defining the ROI where the ZED SDK perform the processing ignoring the rest. Coordinates must be normalized to '1.0' to be resolution independent.
apply_to_positional_tracking: true # Apply ROI to positional tracking processing
apply_to_spatial_mapping: true # Apply ROI to spatial mapping processing
publish_roi_mask: false # Advertise the ROI mask image topic that is published only if a node subscribes to it
depth:
depth_mode: 'NEURAL' # Matches the ZED SDK setting: 'NONE', 'PERFORMANCE', 'QUALITY', 'ULTRA', 'NEURAL', 'NEURAL_PLUS' - Note: if 'NONE' all the modules that requires depth extraction are disabled by default (Pos. Tracking, Obj. Detection, Mapping, ...)
depth_stabilization: 20 # Forces positional tracking to start if major than 0 - Range: [0,100]
point_cloud_freq: 30.0 # [DYNAMIC] Frequency of the pointcloud publishing. This value must be equal or less than the camera framerate.
point_cloud_res: 'COMPACT' # The resolution used for point cloud publishing - 'COMPACT'-Standard resolution. Optimizes processing and bandwidth, 'REDUCED'-Half resolution. Low processing and bandwidth requirements
depth_confidence: 95 # [DYNAMIC]
publish_depth_map: true # Advertise the depth map topics that are published only if a node subscribes to them
publish_depth_info: false # Advertise the depth info topic that is published only if a node subscribes to it
publish_point_cloud: false # Advertise the point cloud topic that is published only if a node subscribes to it
publish_depth_confidence: true # Advertise the depth confidence topic that is published only if a node subscribes to it
publish_disparity: false # Advertise the disparity topic that is published only if a node subscribes to it
pos_tracking:
pos_tracking_enabled: false # True to enable positional tracking from start
pos_tracking_mode: 'GEN_3' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2', 'GEN_3'
imu_fusion: false # enable/disable IMU fusion. When set to false, only the optical odometry will be used.
publish_tf: false # [overwritten by launch file options] publish `odom -> camera_link` TF
publish_map_tf: false # [overwritten by launch file options] publish `map -> odom` TF
map_frame: 'map'
odometry_frame: 'odom'
area_file_path: '' # Path to the area memory file for relocalization and loop closure in a previously explored environment.
save_area_memory_on_closing: false # Save Area memory before closing the camera if `area_file_path` is not empty. You can also use the `save_area_memory` service to save the area memory at any time.
publish_3d_landmarks: false # Publish 3D landmarks used by the positional tracking algorithm
publish_lm_skip_frame: 5 # Publish the landmarks every X frames to reduce bandwidth. Set to 0 to publish all landmarks
fixed_z_value: 0.0 # Value to be used for Z coordinate if `two_d_mode` is true
reset_pose_with_svo_loop: true # Reset the camera pose the `initial_base_pose` when the SVO loop is enabled and the SVO playback reaches the end of the file.
publish_odom_pose: true # Advertise the odometry and pose topics that are published only if a node subscribes to them
publish_pose_cov: false # Advertise the pose with covariance topic that is published only if a node subscribes to it
publish_cam_path: false # Advertise the camera odometry and pose path topics that are published only if a node subscribes to them
gnss_fusion:
gnss_fusion_enabled: false # fuse 'sensor_msg/NavSatFix' message information into pose data
gnss_fix_topic: '/fix' # Name of the GNSS topic of type NavSatFix to subscribe [Default: '/gps/fix']
target_translation_uncertainty: 0.1 # defines the target translation uncertainty at which the calibration process between GNSS and VIO concludes. By default, the threshold is set at 10 centimeters.
target_yaw_uncertainty: 0.1 # defines the target yaw uncertainty at which the calibration process between GNSS and VIO concludes. The unit of this parameter is in radian. By default, the threshold is set at 0.1 radians.
mapping:
mapping_enabled: false # True to enable mapping t # Pand fused point cloud pubblication
publish_det_plane: false # Advertise the plane detection topics that is published only if a node subscribes to it
object_detection:
enable_tracking: true # Whether the object detection system includes object tracking capabilities across a sequence of images.
detection_model: 'MULTI_CLASS_BOX_FAST' # 'MULTI_CLASS_BOX_FAST', 'MULTI_CLASS_BOX_MEDIUM', 'MULTI_CLASS_BOX_ACCURATE', 'PERSON_HEAD_BOX_FAST', 'PERSON_HEAD_BOX_ACCURATE', 'CUSTOM_YOLOLIKE_BOX_OBJECTS'
max_range: 20.0 # [m] Upper depth range for detections.The value cannot be greater than 'depth.max_depth'
filtering_mode: 'NMS3D' # Filtering mode that should be applied to raw detections: 'NONE', 'NMS3D', 'NMS3D_PER_CLASS'
prediction_timeout: 2.0 # During this time [sec], the object will have OK state even if it is not detected. Set this parameter to 0 to disable SDK predictions
# Other parameters are defined in the 'object_detection.yaml' and 'custom_object_detection.yaml' files
body_tracking:
body_format: 'BODY_38' # 'BODY_18','BODY_34','BODY_38'
max_range: 15.0 # [m] Defines a upper depth range for detections
stream_server:
bitrate: 12500 # [1000 - 60000] Streaming bitrate (in Kbits/s) used for streaming. See https://www.stereolabs.com/docs/api/structsl_1_1StreamingParameters.html#a873ba9440e3e9786eb1476a3bfa536d0
target_framerate: 0 # Framerate for the streaming output. This framerate must be below or equal to the camera framerate. Allowed framerates are 15, 30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken.
thread_sched_policy: 'SCHED_BATCH' # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
debug:
sdk_verbose_log_file: '' # Path to the file where the ZED SDK will log its messages. If empty, no file will be created. The log level can be set using the `sdk_verbose` parameter.
use_pub_timestamps: false # Use the current ROS time for the message timestamp instead of the camera timestamp. This is useful to test data communication latency.
debug_common: false
debug_sim: false
debug_video_depth: false
debug_camera_controls: false
debug_point_cloud: false
debug_gnss: false
debug_sensors: false
debug_mapping: false
debug_terrain_mapping: false
debug_object_detection: false
debug_body_tracking: false
debug_roi: false
debug_streaming: false
debug_advanced: false
debug_nitros: false
disable_nitros: false # If available, disable NITROS usage for debugging and testing purposes
