I find the ZED360.exe tool brilliant as well as the sample of the body_tracking multi_camera named fused_camera.py found below:
# Copyright (c) 2022, STEREOLABS.
# All rights reserved.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This sample shows how to detect a human bodies and draw their
modelised skeleton in an OpenGL window
import cv2
import sys
import pyzed.sl as sl
import time
import ogl_viewer.viewer as gl
import numpy as np
if __name__ == "__main__":
if len(sys.argv) < 2:
print("This sample display the fused body tracking of multiple cameras.")
print("It needs a Localization file in input. Generate it with ZED 360.")
print("The cameras can either be plugged to your devices, or already running on the local network.")
exit(1)
filepath = sys.argv[1]
fusion_configurations = sl.read_fusion_configuration_file(filepath, sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP, sl.UNIT.METER)
if len(fusion_configurations) <= 0:
print("Invalid file.")
exit(1)
senders = {}
network_senders = {}
# common parameters
init_params.depth_mode = sl.DEPTH_MODE.ULTRA
init_params.camera_resolution = sl.RESOLUTION.HD720
communication_parameters = sl.CommunicationParameters()
communication_parameters.set_for_shared_memory()
positional_tracking_parameters.set_as_static = True
body_tracking_parameters = sl.BodyTrackingParameters()
body_tracking_parameters.detection_model = sl.BODY_TRACKING_MODEL.HUMAN_BODY_ACCURATE
body_tracking_parameters.body_format = sl.BODY_FORMAT.BODY_18
body_tracking_parameters.enable_body_fitting = False
body_tracking_parameters.enable_tracking = False
for conf in fusion_configurations:
print("Try to open ZED", conf.serial_number)
init_params.input = sl.InputType()
# network cameras are already running, or so they should
if conf.communication_parameters.comm_type == sl.COMM_TYPE.LOCAL_NETWORK:
network_senders[conf.serial_number] = conf.serial_number
# local camera needs to be run form here, in the same process than the fusion
else:
init_params.input = conf.input_type
senders[conf.serial_number] = sl.Camera()
init_params.set_from_serial_number(conf.serial_number)
status = senders[conf.serial_number].open(init_params)
print("Error opening the camera", conf.serial_number, status)
del senders[conf.serial_number]
continue
status = senders[conf.serial_number].enable_positional_tracking(positional_tracking_parameters)
print("Error enabling the positional tracking of camera", conf.serial_number)
continue
status = senders[conf.serial_number].enable_body_tracking(body_tracking_parameters)
print("Error enabling the body tracking of camera", conf.serial_number)
continue
senders[conf.serial_number].start_publishing(communication_parameters)
print("Camera", conf.serial_number, "is open")
if len(senders) + len(network_senders) < 1:
print("No enough cameras")
exit(1)
print("Senders started, running the fusion...")
init_fusion_parameters = sl.InitFusionParameters()
init_fusion_parameters.coordinate_system = sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP
init_fusion_parameters.coordinate_units = sl.UNIT.METER
init_fusion_parameters.output_performance_metrics = False
init_fusion_parameters.verbose = True
fusion = sl.Fusion()
camera_identifiers = []
fusion.init(init_fusion_parameters)
print("Cameras in this configuration : ", len(fusion_configurations))
# warmup
bodies = sl.Bodies()
for serial in senders:
zed = senders[serial]
zed.retrieve_bodies(bodies)
for i in range(0, len(fusion_configurations)):
conf = fusion_configurations[i]
uuid = sl.CameraIdentifier()
uuid.serial_number = conf.serial_number
print("Subscribing to", conf.serial_number, conf.communication_parameters.comm_type)
status = fusion.subscribe(uuid, conf.communication_parameters, conf.pose)
if status != sl.FUSION_ERROR_CODE.SUCCESS:
print("Unable to subscribe to", uuid.serial_number, status)
else:
camera_identifiers.append(uuid)
print("Subscribed.")
if len(camera_identifiers) <= 0:
print("No camera connected.")
exit(1)
body_tracking_fusion_params = sl.BodyTrackingFusionParameters()
body_tracking_fusion_params.enable_tracking = True
body_tracking_fusion_params.enable_body_fitting = False
fusion.enable_body_tracking(body_tracking_fusion_params)
rt = sl.BodyTrackingFusionRuntimeParameters()
rt.skeleton_minimum_allowed_keypoints = 7
viewer = gl.GLViewer()
viewer.init()
# Create ZED objects filled in the main loop
single_bodies = [sl.Bodies]
while (viewer.is_available()):
if fusion.process() == sl.FUSION_ERROR_CODE.SUCCESS:
# Retrieve detected objects
fusion.retrieve_bodies(bodies, rt)
# for debug, you can retrieve the data send by each camera, as well as communication and process stat just to make sure everything is okay
# for cam in camera_identifiers:
# fusion.retrieveBodies(single_bodies, rt, cam);
viewer.update_bodies(bodies)
for sender in senders:
senders[sender].close()
viewer.exit()
However, I would need to retrieve various information from the different skeletons (their position in the room, barycenter, …). Which lines of python code should I add? I think all this data is stored in bodies, but how can I see it and manipulate it?
Thanks in advance,
Antoine
