I am trying to get the depth map as a video from the zed camera in ultra mode but when I use retrieveImage function the depth map video that i get doesn’t match the zed depth viewer depth map that it shows by default…any way to get the same one through your API
Hi @KaushikIswary
Can you post the images of what you get and what you expect to compare them?
Can you also please post the code that you are using to retrieve the depth image?
