Hello, I would like to ask a question about the coordinate systems in zed.
I know that the zed uses right-handed with the positive Y-axis pointing down, X-axis pointing right and Z-axis pointing away from the camera." by default: Coordinate Frames | Stereolabs
Now I want to change it to opengl coordinate, which is sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP
I am processing pre-recorded svo files. During recording, I did not specify the coordinate system cause I thought I can change it when I loaded it. However, I found that it does not work, i.e., no matter what coordinate system I specify when I load svo files, it will always be the default one. Does it mean that I should specify the coordinate system when I record the video?
