Hi everyone, while i’m trying to open docker container in zed box i couldn’t manage to run it with “–runtime”, “nvidia”, argument, so after some research i thought upgrading zed box’ OS to 22.04 from 20.04 could be a good idea. However after the upgrade I found that the docker doesn’t run even without any argument, which should easily work, due to some cgroup mismatch. As you can imagine, I decided to go back and followed the link below for that: Reset your ZED Box Orin NX - Stereolabs. As you can understand I’m trying to downgrade and doing it with USB flash drive. My device serial number begins with GTW-ONX1 and as mentioned I experience problem while trying force recovey but the link as mentioned " using the stardard methods.
" is redirecting to a completely irrelevant page. So my main problem here I can’t switch it to recovery mode and I want to donwgrade it from Ubuntu 22.04 to Ubuntu 20.04. Thanks/Best Regards
Hi @harunresit
Thank you for reporting the broken link. It has already been fixed and the updated is being deployed just now
Concerning your problem. please write an email to support@stereolabs.com adding all the relevant details and logs
