Cuda is used for computation purposes by the ZED SDK. If you do not have an Nvidia GPU you can still use the ZED as a standard USB camera.
If you want to record data to later process them with the ZED SDK you can install the ZED SDK on your laptop, it will tell you that you do not have an Nvidia GPU but you can force it.
This way you will be able to run to tool ZED_Explorer which let you record SVO file that could later be processed on antother device.
