I am trying to record video from ZED left camera using openCV, so far I can only capture left image. But I need it to record live video either in mp4 or avi.
My script works if I use my webcam but it won’t work with zed camera. Below is my script, kindly note that I am still new to opencv and might need a detailed explanation on how to fix this
import sys
import pyzed.sl as sl
import numpy as np
import cv2
import numpy
from pathlib import Path
import enum
def main():
# Create a Camera object
zed = sl.Camera()
init_params.camera_resolution = sl.RESOLUTION.HD1080 # Use HD1080 video mode
init_params.camera_fps = 30 # Set fps at 30
init_params.svo_real_time_mode = False # Don't convert in realtime
# Open the camera
err = zed.open(init_params)
exit(1)
# Prepare new image size to retrieve half-resolution images
image_size = zed.get_camera_information().camera_resolution
image_size.width = image_size.width /2
image_size.height = image_size.height /2
i = 0
image = sl.Mat(image_size.width, image_size.height, sl.MAT_TYPE.U8_C4)
left_image = sl.Mat()
img_rgba = np.zeros((height, width, 4), dtype=np.uint8)
#writer = cv2.VideoWriter('basicvideo.mp4', cv2.VideoWriter_fourcc(*'DIVX'), 20, (image_size.width, image_size.height))
video_writer = cv2.VideoWriter('basicvideo.avi',
cv2.VideoWriter_fourcc('M', '4', 'S', '2'),
max(zed.get_camera_information().camera_fps, 25),
(image_size.width, height))
while True:
# Grab an image, a RuntimeParameters object must be given to grab()
# A new image is available if grab() returns SUCCESS
zed.retrieve_image(image, sl.VIEW.LEFT)
img = image.get_data()
cv2.imshow("Image", img)
k = cv2.waitKey(1)
img_out = cv2.cvtColor(img, cv2.COLOR_RGBA2RGB)
video_writer.write(img_out)
if k % 256 == 27:
# ESC pressed
print("Close app")
break
elif k % 256 == 32:
# SPACE pressed
img_name = 'img_cap_{}.jpg'.format(i)
img = image.write(img_name)
print("{} written!".format(img_name))
i += 1
# Close the camera
zed.close()
if name == “main”:
main()
