Realtime object position estimation using yolo v7 and ZED 2?
Hi everyone, I wanted to do a realtime object position estimation (3D world coordinates) using ZED 2 Cam. I have custom trained YOLOV7 model using github repository : GitHub - pHidayatullah/yolov7: Implementation of paper - YOLOv7: Trainable bag-of-freebies sets new state-of-the-art for real-time object detectors which detects traffic cones. How do I load Yolov7 weights i.e in pt format and cfg file in .yaml format to my code.
Thanks in advance!!
Hello and welcome to our forum,
To ingest external object detections into our SDK, we provide Custom Object Detection : Using the Object Detection API with a Custom Detector | Stereolabs
You can check out our examples from here : zed-examples/object detection/custom detector at master · stereolabs/zed-examples · GitHub
You can probably reproduce what is done in the yolov5 example.
Antoine
Hi team… I did custom object detection in yolov7 pyTorch mode. Here is the code :
#!/usr/bin/env python3
import sys
import numpy as np
from OpenGL.GLUT import *
import argparse
import torch
import cv2
import pyzed.sl as sl
import torch.backends.cudnn as cudnn
sys.path.insert(0, ‘./yolov7-gpu’)
from models.experimental import attempt_load
from utils.general import check_img_size, non_max_suppression, scale_coords, xyxy2xywh
from utils.torch_utils import select_device
from utils.datasets import letterbox
from threading import Lock, Thread
from time import sleep
import ogl_viewer.viewer as gl
import cv_viewer.tracking_viewer as cv_viewer
lock = Lock()
run_signal = False
exit_signal = False
def img_preprocess(img, device, half, net_size):
net_image, ratio, pad = letterbox(img[:, :, :3], net_size, auto=False)
net_image = net_image.transpose((2, 0, 1))[::-1] # HWC to CHW, BGR to RGB
net_image = np.ascontiguousarray(net_image)
img = torch.from_numpy(net_image).to(device)
img = img.half() if half else img.float()  # uint8 to fp16/32
img /= 255.0  # 0 - 255 to 0.0 - 1.0
if img.ndimension() == 3:
    img = img.unsqueeze(0)
return img, ratio, pad
def xywh2abcd(xywh, im_shape):
output = np.zeros((4, 2))
# Center / Width / Height -> BBox corners coordinates
x_min = (xywh[0] - 0.5*xywh[2]) * im_shape[1]
x_max = (xywh[0] + 0.5*xywh[2]) * im_shape[1]
y_min = (xywh[1] - 0.5*xywh[3]) * im_shape[0]
y_max = (xywh[1] + 0.5*xywh[3]) * im_shape[0]
# A ------ B
# | Object |
# D ------ C
output[0][0] = x_min
output[0][1] = y_min
output[1][0] = x_max
output[1][1] = y_min
output[2][0] = x_min
output[2][1] = y_max
output[3][0] = x_max
output[3][1] = y_max
return output
def detections_to_custom_box(detections, im, im0):
output = []
for i, det in enumerate(detections):
if len(det):
det[:, :4] = scale_coords(im.shape[2:], det[:, :4], im0.shape).round()
gn = torch.tensor(im0.shape)[[1, 0, 1, 0]] # normalization gain whwh
        for *xyxy, conf, cls in reversed(det):
            xywh = (xyxy2xywh(torch.tensor(xyxy).view(1, 4)) / gn).view(-1).tolist()  # normalized xywh
            # Creating ingestable objects for the ZED SDK
            obj = sl.CustomBoxObjectData()
            obj.bounding_box_2d = xywh2abcd(xywh, im0.shape)
            obj.label = cls
            obj.probability = conf
            obj.is_grounded = False
            output.append(obj)
return output
def torch_thread(weights, img_size, conf_thres=0.2, iou_thres=0.45):
global image_net, exit_signal, run_signal, detections
print("Intializing Network...")
device = select_device()
half = device.type != 'cpu'  # half precision only supported on CUDA
imgsz = img_size
# Load model
model = attempt_load(weights, map_location=device)  # load FP32
stride = int(model.stride.max())  # model stride
imgsz = check_img_size(imgsz, s=stride)  # check img_size
if half:
    model.half()  # to FP16
cudnn.benchmark = True
# Run inference
if device.type != 'cpu':
    model(torch.zeros(1, 3, imgsz, imgsz).to(device).type_as(next(model.parameters())))  # run once
while not exit_signal:
    if run_signal:
        lock.acquire()
        img, ratio, pad = img_preprocess(image_net, device, half, imgsz)
        pred = model(img)[0]
        det = non_max_suppression(pred, conf_thres, iou_thres)
        # ZED CustomBox format (with inverse letterboxing tf applied)
        detections = detections_to_custom_box(det, img, image_net)
        lock.release()
        run_signal = False
    sleep(0.01)
def main():
capture_thread = Thread(target=torch_thread,
                        kwargs={'weights': opt.weights, 'img_size': opt.img_size, "conf_thres": opt.conf_thres})
capture_thread.start()
print("Initializing Camera...")
zed = sl.Camera()
input_type = sl.InputType()
if opt.svo is not None:
    input_type.set_from_svo_file(opt.svo)
init_params = sl.InitParameters(input_t=input_type, svo_real_time_mode=True)
init_params.camera_resolution = sl.RESOLUTION.HD720
init_params.depth_mode = sl.DEPTH_MODE.ULTRA  # QUALITY
init_params.depth_maximum_distance = 50
    print(repr(status))
    exit()
image_left_tmp = sl.Mat()
print("Initialized Camera")
# If the camera is static, uncomment the following line to have better performances and boxes sticked to the ground.
# positional_tracking_parameters.set_as_static = True
zed.enable_positional_tracking(positional_tracking_parameters)
obj_param.detection_model = sl.DETECTION_MODEL.CUSTOM_BOX_OBJECTS
obj_param.enable_tracking = True
zed.enable_object_detection(obj_param)
objects = sl.Objects()
# Display
camera_infos = zed.get_camera_information()
# Create OpenGL viewer
viewer = gl.GLViewer()
point_cloud_res = sl.Resolution(min(camera_infos.camera_resolution.width, 720),
                                min(camera_infos.camera_resolution.height, 404))
point_cloud_render = sl.Mat()
viewer.init(camera_infos.camera_model, point_cloud_res, obj_param.enable_tracking)
point_cloud = sl.Mat(point_cloud_res.width, point_cloud_res.height, sl.MAT_TYPE.F32_C4, sl.MEM.CPU)
image_left = sl.Mat()
# Utilities for 2D display
display_resolution = sl.Resolution(min(camera_infos.camera_resolution.width, 1280),
                                   min(camera_infos.camera_resolution.height, 720))
image_scale = [display_resolution.width / camera_infos.camera_resolution.width, display_resolution.height / camera_infos.camera_resolution.height]
image_left_ocv = np.full((display_resolution.height, display_resolution.width, 4), [245, 239, 239, 255], np.uint8)
# Utilities for tracks view
camera_config = zed.get_camera_information().camera_configuration
tracks_resolution = sl.Resolution(400, display_resolution.height)
track_view_generator = cv_viewer.TrackingViewer(tracks_resolution, camera_config.camera_fps,
                                                init_params.depth_maximum_distance)
track_view_generator.set_camera_calibration(camera_config.calibration_parameters)
image_track_ocv = np.zeros((tracks_resolution.height, tracks_resolution.width, 4), np.uint8)
# Camera pose
cam_w_pose = sl.Pose()
while viewer.is_available() and not exit_signal:
    if zed.grab(runtime_params) == sl.ERROR_CODE.SUCCESS:
        # -- Get the image
        lock.acquire()
        zed.retrieve_image(image_left_tmp, sl.VIEW.LEFT)
        image_net = image_left_tmp.get_data()
        lock.release()
        run_signal = True
        # -- Detection running on the other thread
        while run_signal:
            sleep(0.001)
        # Wait for detections
        lock.acquire()
        # -- Ingest detections
        zed.ingest_custom_box_objects(detections)
        lock.release()
        zed.retrieve_objects(objects, obj_runtime_param)
        # -- Display
        # Retrieve display data
        zed.retrieve_measure(point_cloud, sl.MEASURE.XYZRGBA, sl.MEM.CPU, point_cloud_res)
        point_cloud.copy_to(point_cloud_render)
        zed.retrieve_image(image_left, sl.VIEW.LEFT, sl.MEM.CPU, display_resolution)
        zed.get_position(cam_w_pose, sl.REFERENCE_FRAME.WORLD)
        # 3D rendering
        viewer.updateData(point_cloud_render, objects)
        # 2D rendering
        np.copyto(image_left_ocv, image_left.get_data())
        cv_viewer.render_2D(image_left_ocv, image_scale, objects, obj_param.enable_tracking)
        global_image = cv2.hconcat([image_left_ocv, image_track_ocv])
        # Tracking view
        track_view_generator.generate_view(objects, cam_w_pose, image_track_ocv, objects.is_tracked)
        cv2.imshow("ZED | 2D View and Birds View", global_image)
        key = cv2.waitKey(10)
        if key == 27:
            exit_signal = True
    else:
        exit_signal = True
viewer.exit()
exit_signal = True
zed.close()
if name == ‘main’:
parser = argparse.ArgumentParser()
parser.add_argument(‘–weights’, nargs=‘+’, type=str, default=‘…/weights/best.pt’, help=‘model.pt path(s)’)
parser.add_argument(‘–svo’, type=str, default=None, help=‘optional svo file’)
parser.add_argument(‘–img_size’, type=int, default=416, help=‘inference size (pixels)’)
parser.add_argument(‘–conf_thres’, type=float, default=0.4, help=‘object confidence threshold’)
opt = parser.parse_args()
with torch.no_grad():
    main()
But I am getting invalid svo error and list index out of range.
Intializing Network…
Initializing Camera…
INVALID SVO FILE
Fusing layers…
RepConv.fuse_repvgg_block
Exception in thread Thread-1 (torch_thread):
File “C:\Users\shirs\Documents\Pythonobjdetection\yolov7-gpu\utils\google_utils.py”, line 26, in attempt_download
assets = [x[‘name’] for x in response[‘assets’]] # release assets
KeyError: ‘assets’
During handling of the above exception, another exception occurred:
File “C:\Users\shirs\anaconda3\envs\yolov7-gpu-env\lib\threading.py”, line 1016, in _bootstrap_inner
self.run()
File “C:\Users\shirs\anaconda3\envs\yolov7-gpu-env\lib\threading.py”, line 953, in run
self._target(*self._args, **self._kwargs)
File “C:\Users\shirs\Documents\Pythonobjdetection\yolov7-gpu\zed44.py”, line 100, in torch_thread
File “C:\Users\shirs\Documents\Pythonobjdetection\yolov7-gpu\models\experimental.py”, line 251, in attempt_load
attempt_download(w)
File “C:\Users\shirs\Documents\Pythonobjdetection\yolov7-gpu\utils\google_utils.py”, line 31, in attempt_download
tag = subprocess.check_output(‘git tag’, shell=True).decode().split()[-1]
IndexError: list index out of range
Pls can you give solution?
