Hi all,
I just bought two Zed 2i, then I plan to use them together.
One fixed on the front side of a vehicle, the second one fixed on the rear side of the vehicle.
The goal is to create a realtime 3D surround view.
So, is there a documentation/tutorial that explains how to fix the position of the two cameras relative of a fixed coordinates then use them for realtime mapping ?
Thank you.
I started my tests but I encounter a bug (?) during the mapping process :
CUDA error at C:\builds\sl\ZEDKit\lib\src\sl_zed\SpatialMappingHandler.cpp:539 code=400(cudaErrorInvalidResourceHandle) "cudaEventRecord(ev_cpu_data, strm)"
Here a minimal test case :
#include <sl/Camera.hpp>
using namespace std;
using namespace sl;
// Create a ZED camera object
Camera zed0;
Camera zed1;
// Set configuration parameters
init_parameters.camera_resolution = RESOLUTION::HD720; // Use HD720 video mode (default fps: 60)
init_parameters.coordinate_system = COORDINATE_SYSTEM::RIGHT_HANDED_Y_UP; // Use a right-handed Y-up coordinate system
init_parameters.coordinate_units = UNIT::METER; // Set units in meters
// Open the camera
init_parameters.input.setFromSVOFile("cam01.svo");
init_parameters.svo_real_time_mode = true;
zed0.open(init_parameters);
init_parameters.input.setFromSVOFile("cam02.svo");
zed1.open(init_parameters);
// Enable positional tracking with default parameters. Positional tracking needs to be enabled before using spatial mapping
sl::PositionalTrackingParameters tracking_parameters;
zed0.enablePositionalTracking(tracking_parameters);
zed1.enablePositionalTracking(tracking_parameters);
// Enable spatial mapping
sl::SpatialMappingParameters mapping_parameters;
zed0.enableSpatialMapping(mapping_parameters);
zed1.enableSpatialMapping(mapping_parameters);
// Grab data during 500 frames
int i = 0;
sl::Mesh mesh0; // Create a mesh object
sl::Mesh mesh1; // Create a mesh object
while (i < 200) {
// For each new grab, mesh data is updated
if (zed0.grab() == ERROR_CODE::SUCCESS) {
// In the background, spatial mapping will use newly retrieved images, depth and pose to update the mesh
sl::SPATIAL_MAPPING_STATE mapping_state = zed0.getSpatialMappingState();
// Print spatial mapping state
cout << "\rImages 0 captured: " << i << " / 500 || Spatial mapping state: " << mapping_state << "\t" << flush;
i++;
if (zed1.grab() == ERROR_CODE::SUCCESS) {
sl::SPATIAL_MAPPING_STATE mapping_state = zed1.getSpatialMappingState();
cout << "\rImages 1 captured: " << i << " / 500 || Spatial mapping state: " << mapping_state << "\t" << flush;
i++;
cout << endl;
// Extract, filter and save the mesh in a obj file
cout << "Extracting Mesh...\n";
zed0.extractWholeSpatialMap(mesh0); // Extract the whole mesh
zed1.extractWholeSpatialMap(mesh1); // Extract the whole mesh
cout << "Filtering Mesh...\n";
mesh0.filter(sl::MeshFilterParameters::MESH_FILTER::LOW); // Filter the mesh (remove unnecessary vertices and faces)
mesh1.filter(sl::MeshFilterParameters::MESH_FILTER::LOW); // Filter the mesh (remove unnecessary vertices and faces)
cout << "Saving Mesh...\n";
mesh0.save("mesh0.obj"); // Save the mesh in an obj file
mesh1.save("mesh1.obj"); // Save the mesh in an obj file
// Disable tracking and mapping and close the camera
zed0.disableSpatialMapping();
zed1.disableSpatialMapping();
zed0.disablePositionalTracking();
zed1.disablePositionalTracking();
zed0.close();
zed1.close();
return EXIT_SUCCESS;
I have the error when I try to adapt the “spatial mapping” sample too.
Config :
Zed SDK : 3.7.2
Cuda : 11.5.119
Processor : i9-11980HK
RAM : 32Go
GPU : Nvidia RTX3080 16Go
OS : Windows 10 Pro
I made another test using the “spacial mapping” sample with the following modified code :
** This sample demonstrates how to capture a live 3D reconstruction of a scene **
** as a fused point cloud and display the result in an OpenGL window. **
// ZED includes
// Sample includes
#include "GLViewer.hpp"
#include <opencv2/opencv.hpp>
// Using std and sl namespaces
using namespace sl;
Camera zed1;
Camera zed2;
// Set configuration parameters for the ZED
init_parameters.depth_mode = DEPTH_MODE::ULTRA;
init_parameters.coordinate_system = COORDINATE_SYSTEM::RIGHT_HANDED_Y_UP; // OpenGL's coordinate system is right_handed
// Open the camera
init_parameters.input.setFromCameraID(0);
init_parameters.input.setFromCameraID(1);
zed2.open(init_parameters);
auto camera_infos = zed1.getCameraInformation();
// Point cloud viewer
GLViewer viewer;
// Initialize point cloud viewer
FusedPointCloud map;
GLenum errgl = viewer.init(argc, argv, camera_infos.camera_configuration.calibration_parameters.left_cam, &map, camera_infos.camera_model);
// Setup and start positional tracking
Pose pose;
POSITIONAL_TRACKING_STATE tracking_state = POSITIONAL_TRACKING_STATE::OFF;
PositionalTrackingParameters positional_tracking_parameters;
positional_tracking_parameters.enable_area_memory = false;
zed1.enablePositionalTracking(positional_tracking_parameters);
zed2.enablePositionalTracking(positional_tracking_parameters);
// Set spatial mapping parameters
SpatialMappingParameters spatial_mapping_parameters;
// Request a Point Cloud
spatial_mapping_parameters.map_type = SpatialMappingParameters::SPATIAL_MAP_TYPE::FUSED_POINT_CLOUD;
// Set mapping range, it will set the resolution accordingly (a higher range, a lower resolution)
spatial_mapping_parameters.set(SpatialMappingParameters::MAPPING_RANGE::SHORT);
spatial_mapping_parameters.set(SpatialMappingParameters::MAPPING_RESOLUTION::HIGH);
// Request partial updates only (only the latest updated chunks need to be re-draw)
spatial_mapping_parameters.use_chunk_only = true;
// Start the spatial mapping
zed1.enableSpatialMapping(spatial_mapping_parameters);
zed2.enableSpatialMapping(spatial_mapping_parameters);
// Timestamp of the last fused point cloud requested
chrono::high_resolution_clock::time_point ts_last1;
chrono::high_resolution_clock::time_point ts_last2;
// Setup runtime parameters
RuntimeParameters runtime_parameters;
// Use low depth confidence avoid introducing noise in the constructed model
runtime_parameters.confidence_threshold = 50;
auto resolution = camera_infos.camera_configuration.resolution;
// Define display resolution and check that it fit at least the image resolution
Resolution display_resolution(min((int)resolution.width, 720), min((int)resolution.height, 404));
// Create a Mat to contain the left image and its opencv ref
Mat image_zed1(display_resolution, MAT_TYPE::U8_C4);
Mat image_zed2(display_resolution, MAT_TYPE::U8_C4);
cv::Mat image_zed_ocv1(image_zed1.getHeight(), image_zed1.getWidth(), CV_8UC4, image_zed1.getPtr<sl::uchar1>(MEM::CPU));
cv::Mat image_zed_ocv2(image_zed2.getHeight(), image_zed2.getWidth(), CV_8UC4, image_zed2.getPtr<sl::uchar1>(MEM::CPU));
// Start the main loop
while (viewer.isAvailable()) {
// Grab a new image
if (zed1.grab(runtime_parameters) == ERROR_CODE::SUCCESS) {
// Retrieve the left image
zed1.retrieveImage(image_zed1, VIEW::LEFT, MEM::CPU, display_resolution);
// Retrieve the camera pose data
tracking_state = zed1.getPosition(pose);
viewer.updatePose(pose, tracking_state);
if (tracking_state == POSITIONAL_TRACKING_STATE::OK) {
auto duration = chrono::duration_cast<chrono::milliseconds>(chrono::high_resolution_clock::now() - ts_last1).count();
// Ask for a fused point cloud update if 500ms have elapsed since last request
if((duration > 500) && viewer.chunksUpdated()) {
// Ask for a point cloud refresh
zed1.requestSpatialMapAsync();
ts_last1 = chrono::high_resolution_clock::now();
// If the point cloud is ready to be retrieved
if(zed1.getSpatialMapRequestStatusAsync() == ERROR_CODE::SUCCESS) {
zed1.retrieveSpatialMapAsync(map);
viewer.updateChunks();
cv::imshow("ZED View 1", image_zed_ocv1);
if (zed2.grab(runtime_parameters) == ERROR_CODE::SUCCESS) {
zed2.retrieveImage(image_zed2, VIEW::LEFT, MEM::CPU, display_resolution);
tracking_state = zed2.getPosition(pose);
//viewer.updatePose(pose, tracking_state);
auto duration = chrono::duration_cast<chrono::milliseconds>(chrono::high_resolution_clock::now() - ts_last2).count();
if ((duration > 500) && viewer.chunksUpdated()) {
zed2.requestSpatialMapAsync();
ts_last2 = chrono::high_resolution_clock::now();
if (zed2.getSpatialMapRequestStatusAsync() == ERROR_CODE::SUCCESS) {
zed2.retrieveSpatialMapAsync(map);
cv::imshow("ZED View 2", image_zed_ocv2);
cv::waitKey(15);
// Save generated point cloud
//map.save("MyFusedPointCloud");
// Free allocated memory before closing the camera
image_zed1.free();
image_zed2.free();
// Close the ZED
zed1.close();
zed2.close();
return 0;
Only the second camera do mapping process and I get the same error in the console window :
Is there a way to use two (or more?) cameras (fixed in rigid body together) to do realtime mapping ?
OK. For an unknown reason, if I compute each zed camera on its own thread, parallele mapping works … a little.
Here my code :
// Copyright (c) 2022, STEREOLABS.
// All rights reserved.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
bool _enableMapping = true;
bool _running = true;
void run(int index, std::mutex &mutex, GLViewer &viewer, sl::FusedPointCloud &map, sl::Transform tf) {
sl::Camera zed;
sl::InitParameters init_parameters;
init_parameters.depth_mode = sl::DEPTH_MODE::PERFORMANCE;
init_parameters.coordinate_system = sl::COORDINATE_SYSTEM::RIGHT_HANDED_Y_UP; // OpenGL's coordinate system is right_handed
init_parameters.coordinate_units = sl::UNIT::MILLIMETER;
init_parameters.camera_resolution = sl::RESOLUTION::HD720;
//init_parameters.camera_fps = 60;
init_parameters.depth_minimum_distance = 200;
init_parameters.sdk_verbose = true;
// Open the camera
init_parameters.input.setFromCameraID(index);
zed.open(init_parameters);
sl::PositionalTrackingParameters positional_tracking_parameters;
positional_tracking_parameters.enable_area_memory = true;
positional_tracking_parameters.enable_imu_fusion = true;
positional_tracking_parameters.initial_world_transform = tf;
zed.enablePositionalTracking(positional_tracking_parameters);
if (_enableMapping) {
sl::SpatialMappingParameters spatial_mapping_parameters;
spatial_mapping_parameters.map_type = sl::SpatialMappingParameters::SPATIAL_MAP_TYPE::FUSED_POINT_CLOUD;
spatial_mapping_parameters.set(sl::SpatialMappingParameters::MAPPING_RANGE::LONG);
spatial_mapping_parameters.set(sl::SpatialMappingParameters::MAPPING_RESOLUTION::HIGH);
zed.enableSpatialMapping(spatial_mapping_parameters);
std::chrono::high_resolution_clock::time_point ts_last;
sl::RuntimeParameters runtime_parameters;
auto camera_infos = zed.getCameraInformation();
sl::Resolution display_resolution(std::min((int)resolution.width, 720), std::min((int)resolution.height, 404));
sl::Mat image_zed(display_resolution, sl::MAT_TYPE::U8_C4);
cv::Mat image_zed_ocv(image_zed.getHeight(), image_zed.getWidth(), CV_8UC4, image_zed.getPtr<sl::uchar1>(sl::MEM::CPU));
std::cout << "Camera " << index << " Type:" << camera_infos.camera_model << " SN:" << camera_infos.serial_number << std::endl;
while (_running) {
if (zed.grab(runtime_parameters) == sl::ERROR_CODE::SUCCESS) {
zed.retrieveImage(image_zed, sl::VIEW::LEFT, sl::MEM::CPU, display_resolution);
sl::Pose pose;
auto tracking_state = zed.getPosition(pose);
viewer.updatePose(index, pose, tracking_state);
if (_enableMapping && tracking_state == sl::POSITIONAL_TRACKING_STATE::OK) {
auto duration = std::chrono::duration_cast<std::chrono::milliseconds>(std::chrono::high_resolution_clock::now() - ts_last).count();
mutex.lock();
zed.extractWholeSpatialMap(map);
mutex.unlock();
// Ask for a fused point cloud update if 100ms have elapsed since last request
if ((duration > 0) && viewer.chunksUpdated()) {
zed.requestSpatialMapAsync();
ts_last = std::chrono::high_resolution_clock::now();
if (zed.getSpatialMapRequestStatusAsync() == sl::ERROR_CODE::SUCCESS && viewer.chunksUpdated() && mutex.try_lock()) {
zed.retrieveSpatialMapAsync(map);
mutex.unlock();
cv::imshow("ZED View : " + std::to_string(index) + " : " + std::to_string(camera_infos.serial_number), image_zed_ocv);
cv::waitKey(10);
image_zed.free();
zed.close();
sl::FusedPointCloud map;
GLViewer viewer;
viewer.init(argc, argv, &map, sl::MODEL::ZED2i);
std::mutex zedmutex;
std::thread zed1thread(run, 0, std::ref(zedmutex), std::ref(viewer), std::ref(map), sl::Transform(sl::Rotation(), sl::Translation(0, 0, -75)));
std::thread zed2thread(run, 1, std::ref(zedmutex), std::ref(viewer), std::ref(map), sl::Transform(sl::Rotation(M_PI, sl::Translation(0, 1, 0)), sl::Translation(0, 0, 75)));
sl::sleep_ms(1);
_running = false;
if (zed1thread.joinable()) zed1thread.join();
if (zed2thread.joinable()) zed2thread.join();
return 0;
It seems the sl::FusedPointCloud does not support very well multiple retrieveSpatialMapAsync() (or extractWholeSpatialMap()) from different cameras because the updated chunks are corrupted as you can see on the following video :
Hi all,
I just updated the SDK to the latest (3.7.4) and I still have the issue while the changelog of this version indicates to have fixed it.
- Fixed spatial mapping invalid behavior when using multiple camera simultaneously
Is there something else wrong ?
Based on your post, I have made this basic sample to reproduce the error:
Camera zed1;
Camera zed2;
// Open the camera
int f = 0;
while (f++ < 700) {
// Grab a new image
if (zed2.grab() == ERROR_CODE::SUCCESS) {
zed1.extractWholeSpatialMap(map);
map.save("ZED1_Map.ply", sl::MESH_FILE_FORMAT::PLY);
map.clear();
zed2.extractWholeSpatialMap(map);
map.save("ZED2_Map.ply", sl::MESH_FILE_FORMAT::PLY);
map.clear();
// Close the ZED
zed1.close();
zed2.close();
return 0;
With the 3.7.4 it runs without errors and exports two point clouds at the end (tested on windows).
Tell me what errors do you have.
Thank you for your answer.
In my use case, I would like to share the same FusedPointCloud on the two cameras for realtime mapping.
And as you can see on the youtube video I sent before, some chunks “blinks” between the two cameras. Maybe there is some conflict between the chunks indexes inside the ZED SDK ?
My bad, I was focus on the SDK error not on your specific request.
Actually the SDK can run simultaneously several cameras but they can not share data. Meaning you can not use the same map for your different cameras.
You see some flickering because each instance of the Camera update a part of the map (as it is not design to do so).
The main part you are missing here is the fact that both camera are not in the same coordinate frame, as they have both their own World. You should take a look at this sample to share the same world across your cameras.
You still won’t be able to have a single map but at least your maps will fit together and you should find a way to merge them.
Thank for your answer and pointing me the error on cameras coordinate frame.
Do you plan to allow multiple cameras mapping sharing the same FusedPointCloud in a future release ?
Or create a “fake” camera which is a combinaison of the two in a rigid body ?
Hi @SL-PY ,
I’m back to this topic.
I’m not sure to understand well how to set the two cameras in the same coordinate frame.
Could you briefly explain me how to do that ?
Do I have to recalibrate the position (using resetPositionalTracking()) of one camera on the other at regular intervals ?
Thank you.
