Raw images extraction
Hello, I am confused regarding the extraction of raw images from SVO files. Could you please clarify a few questions on this topic?
I have two ZED mono cameras and create a virtual stereo pair from them. I save the data from them by recording in ZED Explorer.
Is it possible to extract the raw (unprocessed) image from an SVO file? I have heard that extracted images are rectified.
How does the calibration file influence these images?
Is there way two save save raw images, for example without creation virtual pair ?
Hi @bor_o
We are here to help you :slight_smile:
Are you saving monocular or stereo SVO files?
This depends on how you retrieve the information.
The SVO file contains RAW image streams; you extract the images by using the retrieveImage API function, like you normally do with a live camera.
To extract rectified images, you must use the sl::VIEW::LEFT or sl::VIEW::RIGHT parameter.
To extract unrectified images, you must use the sl::VIEW::LEFT_UNRECTIFIED or sl::VIEW::RIGHT_UNRECTIFIED parameter.
Please read more on the API documentation: C++ / Python
Hi @Myzhar
I am saving stereo SVO files.
Thank you, I missed that option.
