Hi!
Recently I had a problem inverting the depth of the water. I found that the depth_sensing.py doesn’t run as well as the Zed Depth Viewer inversion, how do I set it up so that the depth_sensing.py works like the Zed Depth Viewer?
Zed Depth Viewer:
hi,
you can check the parameters used in DepthViewer in the option widget (the gear icon on the top right corner).
You will be able to update your sample with the same parameters, which are a combinaison of sl::InitParameters (DEPTH_MODE) and RuntimeParameters(SENSING_MODE, confidence) …
