Hi, I am using ZED SDK 4.0.8 on Ubuntu 22.04. I have created a conda environment and run the get_python_api.py script in the environment to install the python api within my environment. The SDK is installed in /usr/local/zed
After activating my environment, running python3 in the terminal and doing import pyzed.sl as sl and zed = sl.Camera() works perfectly fine.
However, when I execute my python script from this environment, I get the following error while importing pyzed.sl as sl: “Unhandled internal exception (slutils)”
Any idea how I can fix this?
