Python SDK 5.0 cannot show images with OpenCV on Jetson
Opencv.imshow refuses to work on my Zed Box with Zed X camera with the new SDK 5.0.
After downgrading back to 4.2 running the same code works again so it appears to be an SDK issue.
Code used to generate the frame:
    zed.retrieve_image(zed_mat_image, sl.VIEW.LEFT)
    zed_image = zed_mat_image.get_data()
    cv2_image = zed_image[:, :, :3]
Hi @asneab2,
Can you share the result of the pip freeze command so we can reproduce the issue?
