安装的anacanda虚拟环境,python3.7和3.8都试过,也已经下载成功,pyzed文件夹在anacanda/envs/zed(自建)/lib/site-packages下,里面有sl.cp37-win_amd64.pyd和_init_.py,不过_init_.py是0kb,用pycharm利用此虚拟环境,import pyzed没什么用,里面没有函数可以调用,求解决办法
Can you run get_python_api.py from within your virtual environment ?
Then if it still does not work, can you send us explanations of what you do and the error messages ?
可以在虚拟环境运行的,并显示已经安装在虚拟环境下了,也可以找到这个安装包,但是调用不了,import pyzed as sl 显示大小为0KB,以下是安装时的运行过程:
(upload://lW3TshKOm7a6nyC8TInRBqxQsKB.jpeg)
it’s not
import pyzed as sl
but
import pyzed.sl as sl
不对,我试过,import pyzed.sl as sl会显示没有名称为‘sl’的模块
Can you try outside of conda, with the tutorial 1 for example ?
