Hi @kankanzheli
If you want to see the same point cloud in Rviz as the point cloud that you see in ZED Depth Viewer you must use the same parameters:
- Camera resolution
- Depth mode
- Depth Confidence
- minimum depth value
They are available in the configuration file common.yaml and zedm.yaml.
You can read more in the online documentation:
https://www.stereolabs.com/docs/ros/zed-node/#zed-parameters
