How can I supply power ZED Link Mono Capture Card? Requires external 12-19V power supply but i don’t see DC jack.
Hi @Rareba
The ZED Link Mono box includes a JST to Jack adapter:
Tank you. What type of jack connector is it? How many amps does the card need?
It’s a jack connector of the same type as the connectors on ZED Link Duo card, so
- inner diameter 2.5 mm
- outer diameter 6.5 mm
The required current is 1A
Ok. I understood. Tank you very much.
