Polarizing Filter for Indoor Firefighting
Dear StereoLabs Community,
I’m working on a research project regarding an autonomous mobile firefighting robot. I plan to use a ZED X Camera and wonder if i should use a polarizing filter. Experiments will happen indoors but there will be a burning object about (50 x 50 x 50)cm big on a small metal stand. The camera is mainly for assessing the flame and partly for navigating the mobile robot. Distance to the burning object is about 2-8m.
One thing to consider is the change in illumination when the fire gets extinguished.
I would really appreciate your insight, thanks!
Hi @nicooblisz
The polarizing filter is only required outdoors to reduce the amount of the flare and glare effects generated by the vertical component of the sunlight waves.
