Point cloud resolution options
I wanted to understand the difference between different point cloud resolutions specified in sl_types.hpp
typedef enum
  PUB,     //!< Same resolution as Color and Depth Map. [Old behavior for compatibility]
  FULL,    //!< Full resolution. Not recommended because slow processing and high bandwidth requirements
  COMPACT,  //!< Standard resolution. Optimizes processing and bandwidth
  REDUCED   //!< Half resolution. Low processing and bandwidth requirements
} PcRes;
std::string toString(const PcRes & res)
  switch (res) {
    case PUB:
      return "PUB";
    case FULL:
      return "FULL";
    case COMPACT:
      return "COMPACT";
    case REDUCED:
      return "REDUCED";
    default:
      return "";
const int NEURAL_W = 896;
const int NEURAL_H = 512;
Why is the NEURAL_W and NEURAL_H set to 896 and 512. what do they represent? What was the intention behind having the consts NEURAL_W and NEURAL_H?
Is that the resolution that the depth is originally computed in and then upsampled or downsampled as needed to satisfy the published pointcloud resolution?
It is an optimized resolution to improve the computing performance of the AI depth processing pipeline.
This is not completely correct. Unfortunately, I cannot disclose too much information because this is part of the internal processing of the ZED SDK pipeline.
Consider 896x512 a magic setting that enables the processing of depth information to speed up.
