Optical center of a lens?
I need to know exact location of the image plane of ZED Mini. I figured out that the focal length is 2.8 mm, but I couldn’t find where lens is exactly located at inside the camera. Is there any hint on this issue?
Thank you for reading this question :slight_smile:
The best approximation for the position of the camera sensor relative to the edge of the lens holder is 24 mm. See attached photo for reference
Thank you for your kind help! This solved my issue :slight_smile:
