Open the Depth mode: NEURAL through C++
I tried to open the Depth mode: NEURAL through C++ program, but the following error occurred after running it:
\[2025-09-24 12:26:45 UTC\]\[ZED\]\[INFO\] Logging level INFO
\[2025-09-24 12:26:46 UTC\]\[ZED\]\[INFO\] \[Init\]  Depth mode: NEURAL
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[INFO\] \[Init\]  Camera successfully opened.
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[INFO\] \[Init\]  Camera FW version: 1523
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[INFO\] \[Init\]  Video mode: HD720@30
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[INFO\] \[Init\]  Serial Number: S/N 36595323
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[ERROR\] \[Object Detection\]  TensorRT library not found
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[ERROR\] \[ZED\] \[Depth\]  NEURAL TRT NOT FOUND
\[2025-09-24 12:26:47 UTC\]\[ZED\]\[WARNING\] CORRUPTED SDK INSTALLATION in enum sl::ERROR_CODE \__cdecl sl::camera::open(struct sl::InitParameters)
However, I have installed tensorrt10.10.0.31 and configured it in VS2022, but the error still occurs. The following is my diagnostic report. I look forward to your reply
“AI Models”: {
“info”: \[
“NEURAL LIGHT DEPTH is not optimized”,
“NEURAL DEPTH is not optimized”,
“NEURAL PLUS DEPTH is not optimized”
“Camera Test”: {
“InternalDevicesCount (GMSL)”: 0,
“InternalDevicesCount (USB)”: 2,
“ZEDCount”: 1,
“ZEDs”: \[
“camera”: {
“Device ID”: 0,
“Firmware”: 1523,
“Init Output”: “OK”,
“Model”: “ZED 2i”,
“Serial Number”: 36595323,
“valid”: \[
“**Camera:** ZED 2i”,
“**Firmware:** 1523”
“resolutions”: {
“HD1080@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 1080,
“height (output)”: 1080,
“initialization”: “OK”,
“status”: true,
“width (input)”: 1920,
“width (output)”: 1920
“HD1080@30”: {
“fps (input)”: 30,
“fps (output)”: 28,
“status”: true,
“HD2K@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 1242,
“height (output)”: 1242,
“status”: true,
“width (input)”: 2208,
“width (output)”: 2208
“HD720@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 720,
“height (output)”: 720,
“status”: true,
“width (input)”: 1280,
“width (output)”: 1280
“HD720@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“HD720@60”: {
“dropCount”: 97,
“fps (input)”: 60,
“fps (output)”: 60,
“imageCount”: 403,
“status”: true,
“tearingCount”: 0,
“VGA@100”: {
“fps (input)”: 100,
“fps (output)”: 83,
“height (input)”: 376,
“height (output)”: 376,
“status”: true,
“width (input)”: 672,
“width (output)”: 672
“VGA@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“VGA@30”: {
“fps (input)”: 30,
“fps (output)”: 29,
“status”: true,
“VGA@60”: {
“fps (input)”: 60,
“fps (output)”: 49,
“status”: true,
“sensors”: {
“Firmware”: 777,
“Model”: “ZED 2i (MCU)”,
“Devices”: {
“ASMediaFound”: false,
“CorruptedFirmware”: false,
“MCUDetected”: true,
“OC_Cam_Detected”: false,
“OtherUSBDevices”: \[
“USBList”: \[
“USB_path”: “/4”,
“idProduct”: “0xc092”,
“idVendor”: “0x046d”
“USB_path”: “/6”,
“idProduct”: “0x00a6”,
“idVendor”: “0x30c9”
“USB_path”: “/12”,
“idProduct”: “0xc992”,
“idVendor”: “0x048d”
“USBMode”: 3,
“USB_path”: “/17”,
“bDescriptorType”: 1,
“bDeviceProtocol”: 1,
“bLength”: 18,
“bMaxPacketSize0”: 9,
“bNumConfigurations”: 1,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“bcdUSBSubClass”: 2,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“idProduct”: “0xf880”,
“idVendor”: “0x2b03”
“USB_path”: “/6”,
“USB_path”: “/9”,
“idProduct”: “0x5088”,
“idVendor”: “0x320f”
“USBMode”: 3,
“USB_path”: “/17”,
“bLength”: 18,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“USBMode”: 2,
“USB_path”: “/3/2”,
“bDeviceProtocol”: 0,
“bLength”: 18,
“bMaxPacketSize0”: 64,
“bcdDevice”: “3.9”,
“bcdUSB”: “2.0”,
“bcdUSBClass”: 0,
“bcdUSBSubClass”: 0,
“busNumber”: 1,
“device”: “ZED2i MCU”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 3,
“idProduct”: “0xf881”,
“USB_path”: “/9”,
“USB_path”: “/3”,
“idProduct”: “0x2512”,
“idVendor”: “0x0424”
“USB_path”: “/14”,
“idProduct”: “0x5852”,
“idVendor”: “0x0bda”
“USBMode”: 3,
“ZED Camera Module Detected”: 63616,
“ZED MCU Module Detected”: 63617,
“ZEDDetected”: true,
“captureDevices”: \[
“controllers”: \[
“CompatibleIDs”: “PCI\\VEN_8086&DEV_7A60&REV_11”,
“Description”: “&\\b USB xHCI  ;: 6h”,
“DeviceName”: “Intel(R) USB 3.20  iU;: 6h - 1.20 (Microsoft)”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\\0000”,
“Location”: “PCI ;  0\\u0001 \\u0007 20\\u0001   0”,
“Manufacturer”: “\\u001a( USB xHCI ;: 6h”,
“Name”: “PCI”,
“PhysicalName”: “\\Device\\NTPNP_PCI0005”
“CompatibleIDs”: “”,
“Description”: “USB 9ƿh(USB 3.0)”,
“DeviceName”: “”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\\0001”,
“Location”: “”,
“Manufacturer”: “(\\u0007  USB ƿh)”,
“Name”: “USB”,
“PhysicalName”: “\\Device\\USBPDO-0”
“CompatibleIDs”: “USB\\USB20_HUB”,
“Description”: “\\u001a( USB ƿh”,
“DeviceName”: “”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\\0013”,
“Location”: “Port\_#0003.Hub\_#0001”,
“Name”: “USB”,
“PhysicalName”: “\\Device\\USBPDO-1”
“error”: \[
“**Low USB bandwidth**  Read our FAQ to troubleshoot your USB connection issues. Learn more **Frame drops:** 97/500 **Frame tearing:** 0/500”
“Graphics Card”: {
“deviceCount”: 1,
“deviceDriverVersion”: 13000,
“devices”: \[
“arch”: “Ada Lovelace”,
“computeCapability”: “8.9”,
“cores”: 3072,
“name”: “NVIDIA GeForce RTX 4060 Laptop GPU”,
“totalMemoryBytes”: “8585216000”,
“totalMemoryMB”: 8187.5
“initResult”: 0,
“valid”: \[
“**Graphics card:**  NVIDIA GeForce RTX 4060 Laptop GPU”
“Processor”: {
“OS”: “Windows 10 FallCreators”,
“avxSupported”: true,
“coreCount”: “16”,
“cpu”: “Intel(R) Core™ i7-14650HX”,
“datetime”: “2025-09-24 20:08:00”,
“hyperThreading”: “1”,
“motherboard”: ", ",
“ramCapacity”: “15.7811”,
“ramUsage”: “0”,
“ramUsed”: “10.0018”,
“threadCount”: “24”,
“valid”: \[
“**Processor:**  Intel(R) Core™ i7-14650HX”
“ZED SDK”: {
“CUDA Toolkit version”: “V12.9.86 -->located in C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.9/bin/nvcc.exe”,
“CUDA loading”: false,
“ZED SDK Version (Diag)”: “5.0.7”,
“ZED SDK Version (RT)”: “5.0.7”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 12090,
“tensorVersion”: 100200
“binFiles”: \[
“nvinfer_10.dll”,
“nvinfer_builder_resource_10.dll”,
“nvinfer_dispatch_10.dll”,
“nvinfer_lean_10.dll”,
“nvinfer_plugin_10.dll”,
“nvinfer_vc_plugin_10.dll”,
“nvonnxparser_10.dll”,
“sl_ai64.dll”,
“sl_zed64.dll”,
“zlibwapi.dll”
“driverVersion”: “581.15”,
“drivervDllVersion”: “32.0.15.8115”,
“resourcesFiles”: \[
“neural_depth_5.3.model”,
“neural_depth_5.3.model_optimized-fbcbw-1-89-12090-100900-9-128-32768-48-100-512-24-0-0e53-512”,
“w100900_timing_cache”
“resourcesFilesExpected”: \[
“objects_performance_3.2”
“runtimeDllVersion”: 12090,
“valid”: \[
“**ZED SDK version:** 5.0.7”,
“**CUDA version:** V12.9.86”
Please uninstall CUDA v12.9 and the ZED SDK.
Then install CUDA v12.6 or v12.8 and reinstall the ZED SDK for CUDA 12 and TensorRT 10.
Please note that you must not install TensorRT manually.
The ZED SDK installer installs the required libraries, and then any manual installation can cause conflicts.
I tried to uninstall CUDA 10.9 and ZED SDK, then reinstalled CUDA 10.8 and CUDA 10.6 respectively. This time, I did not manually install TensorRT. I could still open NEURAL mode through DepthViewer, but failed to open it through C++ program and received the same prompt
Please run ZED Diagnostic again and send the new JSON report.
“AI Models”: {
“info”: [
“valid”: [
“NEURAL DEPTH is optimized”
“Camera Test”: {
“ZEDCount”: 1,
“ZEDs”: [
“camera”: {
“Device ID”: 0,
“Firmware”: 1523,
“Model”: “ZED 2i”,
“valid”: [
“Camera: ZED 2i”,
“Firmware: 1523”
“resolutions”: {
“HD1080@15”: {
“fps (input)”: 15,
“fps (output)”: 12,
“status”: true,
“HD1080@30”: {
“fps (input)”: 30,
“fps (output)”: 11,
“status”: true,
“HD2K@15”: {
“fps (input)”: 15,
“fps (output)”: 14,
“status”: true,
“HD720@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“HD720@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“HD720@60”: {
“dropCount”: 23,
“fps (input)”: 60,
“fps (output)”: 60,
“imageCount”: 477,
“status”: true,
“tearingCount”: 0,
“VGA@100”: {
“fps (input)”: 100,
“fps (output)”: 96,
“status”: true,
“VGA@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“VGA@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“VGA@60”: {
“fps (input)”: 60,
“fps (output)”: 60,
“status”: true,
“sensors”: {
“Firmware”: 777,
“Devices”: {
“OtherUSBDevices”: [
“USBList”: [
“USB_path”: “/4”,
“USB_path”: “/6”,
“USB_path”: “/12”,
“USBMode”: 3,
“USB_path”: “/17”,
“bLength”: 18,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“USB_path”: “/6”,
“USBMode”: 3,
“USB_path”: “/17”,
“bLength”: 18,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“USBMode”: 2,
“USB_path”: “/3/2”,
“bLength”: 18,
“bcdDevice”: “3.9”,
“bcdUSB”: “2.0”,
“bcdUSBClass”: 0,
“busNumber”: 1,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 3,
“USB_path”: “/3”,
“USB_path”: “/14”,
“USBMode”: 3,
“captureDevices”: [
“controllers”: [
“CompatibleIDs”: “PCI\VEN_8086&DEV_7A60&REV_11”,
“Description”: “&\b USB xHCI ;: 6h”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\0000”,
“Location”: “PCI ; 0\u0001 \u0007 20\u0001 0”,
“Manufacturer”: “\u001a( USB xHCI ;: 6h”,
“Name”: “PCI”,
“PhysicalName”: “\Device\NTPNP_PCI0005”
“DeviceName”: “”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\0001”,
“Location”: “”,
“Manufacturer”: “(\u0007 USB ƿh)”,
“Name”: “USB”,
“PhysicalName”: “\Device\USBPDO-0”
“CompatibleIDs”: “USB\USB20_HUB”,
“Description”: “\u001a( USB ƿh”,
“DeviceName”: “”,
“Driver”: “{36fc9e60-c465-11cf-8056-444553540000}\0013”,
“Location”: “Port_#0003.Hub_#0001”,
“Name”: “USB”,
“PhysicalName”: “\Device\USBPDO-5”
“warning”: [
“Low USB bandwidth Read our FAQ to troubleshoot your USB connection issues. Learn more Frame drops: 23/500 Frame tearing: 0/500”
“Graphics Card”: {
“deviceCount”: 1,
“devices”: [
“cores”: 3072,
“initResult”: 0,
“valid”: [
“Graphics card: NVIDIA GeForce RTX 4060 Laptop GPU”
“Processor”: {
“coreCount”: “16”,
“datetime”: “2025-09-26 12:48:33”,
“ramUsage”: “0”,
“ramUsed”: “8.64663”,
“valid”: [
“Processor: Intel(R) Core™ i7-14650HX”
“ZED SDK”: {
“CUDA Toolkit version”: “V12.6.20 -->located in C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.6/bin/nvcc.exe”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 12060,
“tensorVersion”: 100900
“binFiles”: [
“nvinfer_10.dll”,
“sl_ai64.dll”,
“sl_zed64.dll”,
“zlibwapi.dll”
“resourcesFiles”: [
“neural_depth_5.3.model_optimized-fbcbw-1-89-12060-100900-9-128-32768-48-100-512-24-0-0e53-512”,
“resourcesFilesExpected”: [
“runtimeDllVersion”: 12060,
“valid”: [
“ZED SDK version: 5.0.7”,
“CUDA version: V12.6.20”
This is the report I got after running the diagnostic tool
What do you get if you try to optimize the AI models by using the ZED Diagnostic tool as described in the documentation?
After the re-optimization, there is no prompt
“AI Models”: {
“info”: [
“valid”: [
“Camera Test”: {
“ZEDCount”: 1,
“ZEDs”: [
“camera”: {
“Device ID”: 0,
“Firmware”: 1523,
“Model”: “ZED 2i”,
“valid”: [
“Camera: ZED 2i”,
“Firmware: 1523”
“resolutions”: {
“HD1080@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“HD1080@30”: {
“fps (input)”: 30,
“fps (output)”: 28,
“status”: true,
“HD2K@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“HD720@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“HD720@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“HD720@60”: {
“dropCount”: -1,
“fps (input)”: 60,
“fps (output)”: 55,
“imageCount”: 502,
“status”: true,
“tearingCount”: 0,
“VGA@100”: {
“fps (input)”: 100,
“fps (output)”: 79,
“status”: true,
“VGA@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“VGA@30”: {
“fps (input)”: 30,
“fps (output)”: 27,
“status”: true,
“VGA@60”: {
“fps (input)”: 60,
“fps (output)”: 59,
“status”: true,
“sensors”: {
“Firmware”: 777,
“Devices”: {
“USBList”: [
“USB_path”: “/9”,
“USB_path”: “/6”,
“USB_path”: “/4”,
“USB_path”: “/12”,
“USBMode”: 3,
“USB_path”: “/17”,
“bLength”: 18,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“USB_path”: “/6”,
“USBMode”: 3,
“USB_path”: “/17”,
“bLength”: 18,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“busNumber”: 1,
“device”: “ZED2i”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 4,
“USBMode”: 2,
“USB_path”: “/3/2”,
“bLength”: 18,
“bcdDevice”: “3.9”,
“bcdUSB”: “2.0”,
“bcdUSBClass”: 0,
“busNumber”: 1,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 3,
“USB_path”: “/4”,
“USB_path”: “/3”,
“USB_path”: “/14”,
“USBMode”: 3,
“captureDevices”: [
“controllers”: [
“Name”: “PCI”,
“DeviceName”: “”,
“Location”: “”,
“Name”: “USB”,
“DeviceName”: “”,
“Name”: “USB”,
“PhysicalName”: “\Device\USBPDO-10”
“valid”: [
“USB Bandwidth: OK”
“Graphics Card”: {
“deviceCount”: 1,
“devices”: [
“cores”: 3072,
“initResult”: 0,
“valid”: [
“Processor”: {
“coreCount”: “16”,
“datetime”: “2025-09-29 22:09:01”,
“ramUsage”: “0”,
“ramUsed”: “9.80232”,
“valid”: [
“ZED SDK”: {
“ai”: {
“checkAI”: true,
“binFiles”: [
“nvinfer_10.dll”,
“sl_ai64.dll”,
“sl_zed64.dll”,
“zlibwapi.dll”
“resourcesFiles”: [
“valid”: [
Now you should be able to visualize the point cloud and the depth map with ZED Explorer.
Please confirm it.
While ZED Explorer cannot visualize point clouds and depth maps, ZED Depth Viewer can properly visualize them using NEURAL Depth Mode. However, I still cannot open NEURAL Depth Mode through C++ calls to ZED SDK.
Sorry, it was a typo. I meant ZED Depth Viewer indeed.
This means that you have not properly configured your environment.
What error do you get? Have you cleaned and rebuilt from scratch?
