I am experienced with coding and deploying the Zed SDK in a linux environment. I’m trying to spin up a windows environment using an eGPU with a GTX 1660 SUPER, and a Zed 2. CUDA-Z and the NVIDIA app can both see the GPU, so I know it’s active and running properly. However, I’m seeing some odd behavior from the Zed SDK:
When I spin up Zed explorer, I can see both video feeds with good frame rate, but the frame rate text at the bottom flickers between “0” and “N/A”.
When I spin up Zed Depth Viewer, I can’t see either video feed, or the depth feed or point cloud, but the FPS text is consistent at 30HZ for the camera and depth.
Any ideas why the apps aren’t quite behaving as expected?
