Hello Stereolabs community,
As I reflashed multiple zed box mini with the procedure supported on Stereolabs’ website, everything is working fine in the new image . However there is no wifi adapter. There is no way to connect to wifi.
Thanks for the support.
Can you try to follow this ?
Hey,
I tried it before, I think I am missing the iwlwifi module:
Please note that I used the reflashing procedure provided by stereolabs.
I fixed the issue, after running the command for deleting the module, I ran:
sudo apt install backport-iwlwifi-dkms
sudo reboot
Thank you for the support.
