No GMSL driver found
Why GMSL driver not found?, but ZED_Depth_Viewer works correctly. im using jetson agx orin dev kit with jetpack 6.0. Is it okay if you don’t consider it?
Hi @ajrillah
what camera model are you using?
Is it a ZED X? If it’s not a GMSL2 camera then you can ignore the warning because you do not need the driver to be installed
i have zed2i, i think i can ignore the warning
Yes, if you use USB3 cameras, you can ignore it.
