I try to use 2 zed 2i at the same time. I need carrier board or system advice to run the system flawlessly. I need to reach board immediatly please recommend out of sterolabs boards
Hi Davide,
If you need an embedded device I recommend using NVIDIA Jetson AGX Orin that provides multiple separate USB3 channels.
Otherwise, a standard laptop with an NVIDIA GPU is good.
